Protection: There are two main degrading agents that attack tires and rubber trim. They are UV light waves and ozone. Both of these attack the long hydrocarbon chains of the rubber and, by breaking these bonds, shorten the molecules with resulting loss of elasticity and other problems. Tire manufacturers add two primary sacrificial protectants to the rubber. To protect against UV, they add carbon black. This is why tires dont come in designer colors to match your paint. The carbon black will turn white/gray as it absorbs the UV and dissipates the energy as heat. This is the basis of rubber parts turning gray as they age. To protect against ozone, tire manufacturers add a wax based, sacrificial protectant. The ozone attacks the wax and depletes it. As the tire rolls, additional wax is forced to the surface of the tire. This is referred to as blooming. This blooming refreshes the surface wax protectant. A tire that has not been flexed will have the wax depleted by the ozone and thus begin to degrade and suffer dry rot. The raw silicone oil that is the main ingredient in most of the nationally advertised, auto parts store, high gloss products may actually dissolve the wax and be the cause of premature tire sidewall cracking/failure. The quality tire/rubber dressings should contain a strong UV protectant to bolster the efforts of the carbon black and not contain any raw silicone oil. Many of the nationally advertised rubber and vinyl products also contain formaldehyde. If you plan on having a funeral for your vinyl/rubber, then you may wish to use one of these products.
Gianni D said:bleche white or A2Z tire cleaner work great for brown tires.
yakky said:I like both on tires, but I think BW has issues with some rims.
skip87 said:say no to foam
