xdreamer2 said:
I've just purchased a brand new 70th Anniversary Jeep Wrangler Unlimited (bright silver w/matching hardtop), just awaiting delivery. I've also got a set of aftermarket matte black wheels going on the jeep.
As soon as I get it home I'm planning to do a wash, Klasse AIO, and FK 1000p...
Are you gonna do any kind of decontamination? Silver vehicles can really show any ferrous contamination/"rust blooms" and you won't know you have the problem until you see the little orange stains (the rust blooms from when the contamination starts to oxidize).
I know this is pretty late to be suggesting it, but IMO it really is worth doing and it's pretty much as simple as doing an extra wash or two with the right stuff.
1. Is it safe to use Klasse AIO on the matte black bumpers, door handles, side steps, fuel door, window trim, matte black wheels? Or should I avoid and/or tape off these areas?
I use KAIO on pretty much *every* exterior surface like that, rubber, plastic, you name it.
I've never had any problems using KAIO on such surfaces, never (oops, well...except for rubbing too hard on soft rubber). But I don't let it dry before I buff it off either. If I were doing it I *would* plan to KAIO those surfaces. BUT, don't make my mistake- don't rub hard on any soft surfaces (e.g., rubber) as you might mess up the factory texture.
2. I'm guessing that I should avoid getting the FK 1000p on these black surfaces as it will add some gloss to any of these matte black areas right?
I've used FK1000P on such surfaces with mixed results. When it works out right it leaves a nice satiny sheen that I really like. But the risk of staining and getting residue stuck in any texture is considerable and IMO you'd just better not use the FK1000P on those surfaces.
Would I try it? Maybe...it worked swell on my Yukon's trim and on the pieces I tried on my Tahoe. But I'd sure hate for you to have it go haywire.
The trick with using FK1000P on such surfaces is to apply as thinly as possible (beyond the usual "apply sealants nice and thin") and to buff it off before it dires (the wipe-on-wipe-off method). And don't try to layer it too much or, IME, you *will* get the residue issue in deeper textures no matter how thin it goes on. Eh....mighty risky.
3. Is there any product I should be using to protect these matte black surfaces?
The KAIO will work for now, but it won't last long at all. See how you like the subtle sheen it leaves (you can always clean it off with IPA or somesuch).
You could top those KAIO'ed surfaces with KSG. Or with Collinite 845.
OR...use the KAIO to clean/prep them, then wipe with IPA to remove the (minimal) stuff KAIO leaves behind, and seal them with Ultima's Trim Sealant or the newly popular "C4" stuff.
Here's a link to a thread discussing the C4:
http://www.autopia.org/forum/car-detailing-product-discussion/134971-g-techniq-c4.html
I'm debating what to use on my newly acquired TBSS, which has a lot of similar trim. I'll probably use either KSG or the Ultima Trim sealant just because I have those on hand. But if I were buying something new, I'd probably lean towards the C4.
I have the OptiCoat stuff, but I'm not ready to try that on such surfaces just yet :think:
