imported_civicdacbiet
What are ur thoughts on this RO/DA?
Model 1250DEVS;
Model 1250DEVS;
6″ Dual-Mode Random Orbit Sander/Polisher
Multiple-purpose sander with two sanding modes: Random Orbit mode for normal stock removal or fine finishing and "Turbo" driven eccentric orbit mode for aggressive stock removal.
Simple sanding mode selector switch - Quickly change between random orbit mode and "Turbo" mode.
Mode selector switch Quickly change between random orbit mode and "Turbo" mode
Random orbit mode-eccentric orbit plus rotation For normal stock removal or fine finishing
"Turbo" driven eccentric orbit mode For aggressive, fast stock removal. 5x random orbit sander removal rate!
Powerful 6.5 amp motor with variable speed (3,100-6,650 OPM) To match speed to work piece and task ensures fast smooth results on all surfaces
Soft Start Reduces start-up torque
Responseâ„¢ circuitry Maintains pad speed under heavy loads and protects against overloads
Integral pad dampening system Helps prevent swirl marks for consistent fine finish
Passive dust collection system Vacuum cleaner and hoses required - accepts Bosch VAC001, VAC009 and VAC010 hoses or VAC002 hose adapter
Variable-speed dial Allows match of speed to workpiece and task
Uses 6-Hole 6″ hook and loop discs Compatible with industry-standard discs
Includes:
Dust Tube -- 2601328072
Soft Backing Pad -- RS6045
Ambidextrous Auxiliary Handle -- 2602025067
Sanding Disc -- Included
Pad Wrench, 5mm (stored on tool) -- 1907950006
Who's got one, used one or has an opinion on the 1250DEVS? Any input would be great because i can't find any reviews on it. Thanks :xyxthumbs
Model 1250DEVS;
Model 1250DEVS;
Includes:
