TheSopranos16
I tried something new the other day (at least it's new to me). I bought one of those pumpable spray bottles that work like an aerosol(Here is the bottle) So, I filled the bottle with BNB diluted 1:1 with water. I wanted it for use particularly on wheel wells but also on tires or under the hood. I found that the spray worked well but at 1:1 the product was still a little thick so it didn't spray as well as it could have. So I was thinking, what if I dilute it with alcohol instead of water??? As I see it, the alcohol would offer a few advantages over water. 1) Alcohol is more viscus than water so it would thin the mix a little and enable it to spray better 2) Alcohol evaporates faster than water so it would dry faster 3) Water tends to "bead up" on a surface more than alcohol does. So, alcohol should enable the product to have more even coverage when it is sprayed.
So, what do you guys think of this idea? I've never mixed anything with alcohol before (except tonic water), although I wouldn't think it would be a problem. Does anyone see anything wrong with this or should I give it a try? Has anyone tried it before? Any feedback is welcome and appreciated. Thanks in advance.
-Charles
-Charles
