Finally had a chance to try these out at the weekend.
Paint was in ok shape was polsihed with Menzerna Final Finish in early September so was washed and dryed and then the car was glazed/polished by hand with Clearkote VM and then treated two coats of Blackfire Wet Diamond Sealant last weekend.
Liking it alot easy on and easy off, great looking, close to Carnuba depth, no flake muting and super slick :thumb: As slick as UPP and with as much depth as Wolfgang and easier to use than both, a little richer in colour than CG M/Seal - so I think I have found a new Summer sealant for next year.
As a Carnuba fan, I could never leave it untopped and had both my Zymol Carbon and 50/50 that turned up at the same time. I had managed a quick test in the garage showed I could not se any noticeable difference between the CG 50/50 and current wax of choice Souveran ( running low on as it is), so it really came down to the Carbon and 50/50.
So so half and half panels:
Rear Quarter: left side Zymol Carbon - right side CG 50/50
Door: left side Zymol Carbon - right side CG 50/50
Bonnet: left side Zymol Carbon - right side CG 50/50
After application I could see no difference between either wax apperance wise. Both sides of the panel looked as good. The only differences where in use, 50/50 spreads easier than the Carbon, which felt almost sticky, where as the 50/50 was slightly harder to remove (both where dead easy off). The main differnce was cost, the 50/50 coming in at half the price of the Carbon here in the UK. Both applied with foam hand pads and removed woth Sonus Der Wunder buffing towels.
After this I proceded to just wax the whole car with the 50/50.
As it was over a sealant no HD Cleanse was used before the Zymol so I will repeat the tests in the summer.
