Blackfire TPnS
Sagers2
Is this good for using on a car that doesn't have any swirl marks? I'm looking for a non abrasive polish that will remove a sealant and get the paint ready to start again. I already have this and was going to top it with BlackIce. Or is this safe enough for my paint. I have a 2014 Black car so the paint is in great shape.
Thanks all!!!
It maybe more than you need. Using the adage of using the least aggressive method, you may want to use BF's Gloss Enhancing Polish instead - as it has no abrasives.
TPnS is such a mild polish, you'll be fine. It's strongest area is cleaning, great base for Blackfire LSP's.
So you think it won't create swirls in my paint using it? I do everything by hand as I'm not brave enough to try a DA yet. This product is a polish and sealant right??
Will it create swirls in my paint using it??
The product itself is not capable of creating swirl marks. The only way it would create swirl marks is if you applied it using a rotary/circular polisher with a WOOL pad, which can be said for any product.
So the short answer is NO. ;)
BLACKFIRE Total Polish & Seal was formulated so it can be applied by hand or machine. :D
No. BF TPnS is designed to remove mild swirl marks, not create new ones. It features a very fine abrasive polish which will burnish the paint to create a more mirror-like finish.
As AutopiaTech masterfully stated, if you use a very abrasive application method, you could create swirl marks, but this would from the abrasion of the pad overriding TPnS's lubrication ability.
The Wet Diamond Tri-Polymers in BF TPnS will compliment the identical polymers found in BlackICE. :)
