Todd@RUPES
Just a regular guy
BLACKFIRE Total Eclipse Tire & Wheel Cleaner
BLACKFIRE Total Eclipse Tire & Wheel Cleaner is a new breed of ultra safe wheel cleaners. It is pH neutral and contains no acids, alkalies, butyls, ethers, or petroleum distillates. It uses advanced non-ionic surfactants that attack brake dust and release dirt and build up from rubber. This wheel cleaner is safe for all wheel finishes.
Safe for:
Note: It is recommended to wash your wheels and tires completely before washing the rest of your car.
Below are some pictures of the starting condition of the wheel.
Getting Started
Having the essential tools necessary to clean the intricate parts of a wheel makes your job much easier, BLACKFIRE Total Eclipse Tire & Wheel Cleaner is an extremely effective wheel cleaner that is very capable of removing stubborn brake dust from tires & wheels, particularly when used with the proper assortment of tools. I personally like to set my tools in a bucket of water and rinse them as I use them. This keeps the tools clean by rinsing them frequently as well as adds water to constantly flush away the brake dust.
Use BLACKFIRE Total Eclipse Tire & Wheel Cleaner one tire at a time. Start by rinsing the wheel and tire with a steady stream of water to remove any loose soiling.
Spray a liberal amount of BLACKFIRE Total Eclipse Tire & Wheel Cleaner over the face of the wheel and tire.
Spray BLACKFIRE Total Eclipse Tire & Wheel Clean into the barrels the wheel or anywhere that soiling is.
Allow to dwell for 30 seconds for the non-ionic surfactants to begin to penetrate and loosen the grime before agitation Use a stiff brush or microfiber towel to agitate the tires first.
Make sure to clean the area of the tire where it meets the wheel. The Short Handle Tire Brush fits perfectly in the recess for easy cleaning.
Next clean any detailed areas with a small, soft brush such as the 1 Inch Round Detail Brush.
BLACKFIRE Tire & Wheel Cleaner will suds slightly upon agitation with water so that you know it is working.
Finish agitating detailed areas such as emblems, center caps, or markings.
Next clean the hard-to-reach areas of the wheel, such as behind the spokes and the barrels with a soft bristle or lambs wool brush.
Not only does the Daytona Speedmaster Wheel Brush feature soft bristles and a reinforced steam, but it fits in between and around the brake caliper (on most wheel/brake combinations) for easy cleaning.
Finally agitate the face of the wheels and spokes with a soft, scratch-free brush like a Montana Boar's Hair Wheel Brush. Work into a light lather.
Next rinse the wheel and tire thoroughly a forceful stream of water. Make sure to rinse behind the spokes and in the barrel of the wheel.
Finally dry your wheel with a microfiber cloth.
Repeat until all wheels & tires are clean and detailed.
Safe for:
- Polished Aluminum
- Chrome
- Painted
- Clear Coated
- Powder Coated
- Anodized
- Tire Rubber and White Walls/Letters
Getting Started
