Product description:
The polish and glaze in one that creates WHIPLASH on all paints!
Visually reduces and removes swirl marks while creating a wet-look shine.
Removes old waxes, sealants, and cleans the paint's surface.
Perfect preparatory step for any wax or sealant!
What's the difference in using a polish to remove a sealant or a product like Car Pro Eraser or are both needed? Am I better off using the polish first then the eraser before sealing??
CarPro is a spray'n'wipe product that removes oils, waxes and sealants from the surface of the paint. BF GEP is a non-abrasive glaze/polish that deep cleans the paint, as well as fills in light imperfections/swirl marks. If you are using BLACKFIRE or similar polymer-based sealants, BF GEP will promote the proper bonding of the polymers to the surface.
Thanks so much for the help. So I am better off sticking with the
Blackfire Polish followed by the Blackfire sealant if I am following you right I guess I am confused, in which case would you use a product like CarPro??
I am going to try soon (Carpro is shipping!) BF Polish (BFEP) followed by CarPro followed by BFWD (Wet Diamond sealant).
for better results, go directly to bfwd after the bfgep and skip the eraser. the eraser will probably remove the glazing left behind by bfgep that helps in filling minor defects and enhancing the finish. car pro eraser is best used after correcting compounds/polishes.
