Todd@RUPES
Just a regular guy
BLACKFIRE Interior Protectant
BLACKFIRE Interior Protectant is the only product you need to maintain the look and feel of leather and soft vinyl upholstery. This 100% water based protectant uses micro-engineered polymers that are readily accepted by leather and soft vinyl. BLACKFIRE Interior Protectant contains no oils, silicones, or petroleum distillates. It leaves a deep, satin, natural-looking finish on interior auto surfaces. This unique protectant is perfectly pH-balanced (7) to match the pH requirements of leather. After treatment, a micro-fine moisture barrier remains on the surface to resist perspiration stains and help retard UV-induced fading.
Instructions
Clean interior surfaces with BLACKFIRE Interior Cleaner or BLACKFIRE All N One All Purpose Interior Cleaner.
Apply BLACKFIRE Interior Protectant by spraying directly onto the surface or misting on a microfiber applicator.
Wipe in over lapping passes to spread evenly on vinyl, trim, and leather.
Allow to penetrate for 1 to 2 minutes then buff off using a Cobra microfiber buffing towel.
If more shine is desired apply a second coat after 20 minutes.
If less sheen is desired mist a microfiber towel with water and buff.
On areas near glass mist directly on a microfiber applicator and apply by hand. If any over spray lands on the glass it can be removed with any glass cleaner.
BLACKFIRE Interior Protectant works great on plastic trim as well. Mist on, wipe into the trim, and buff off with a soft Cobra microfiber towel.
Instructions
