Todd@RUPES
Just a regular guy
BLACKFIRE Interior Cleaner
BLACKFIRE Interior Cleaner is a versatile, water-based cleaner for all interior surfaces. Interior Cleaner contains no acids, butyl, butyl ethers or petroleum distillates. It is formulated with advanced Swedish non-ionic surfactants that it give it the power to remove soiling and oil while being gentle enough to be used on all interior surfaces including carpet, leather, vinyl, wood, fabric, metal, plastic surfaces and upholstery.
Instructions
BLACKFIRE Interior Cleaner is formulated to be as effective as professional cleaners. The non-ionic surfactants are designed to clean powerfully yet gently, any thing that should be able to be cleaned with water can be cleaned with BLACKFIRE Interior Cleaner. We still recommend testing a small inconspicuous spot first to test colorfastness in case of a carpet or leather re-dye.
Clean leather, vinyl, plastic, and metal surfaces by misting the product directly onto to the surface or onto a microfiber applicator pad.
or
Work a section at a time by lightly wiping. If more aggressive cleaning is needed use the microfiber applicator to agitate the surface by using a little more pressure.
To efficiently clean extreme soiling or heavily textured surfaces use a Natural Horse Hair Upholstery Brush or a Vinyl & Leather Scrub Brush.
Wipe surfaces clean with a Cobra Micro Fiber Towel. Unlike some all-purpose and interior cleaners, BLACKFIRE Interior Cleaner is designed to be wiped away with out flushing with water. Gently wipe dry and move on to the next section.
To clean carpet, fabric, and upholstery mist lightly on to the spot.
And agitate with a microfiber applicator pad or Horse Hair Upholstery Brush.
PIC
Pat dry with a Cobra Microfiber Towel. BLACKFIRE Interior Cleaner does not require flushing with water and will not leave behind any residues that attract dirt or oil.
When cleaning headliner lightly mist BLACKFIRE Interior Cleaner onto a microfiber applicator and scrub gently. Avoid saturating the headliner as this can weaken the glue and cause sagging over time.
To clean Metal, Plastic, or Wood Trim mist directly onto the surface.
Instructions
or
PIC
