imported_Aurora40
Ok, I wanted to post my observations with Blackfire. I have the Gloss Enhancing Polish and the Protectant courtesy of SonnyDaze (Thanks again!! :bow :wavey)
When I first got them, I was eager to try them on the car. I currently had some #26 on the car that was about 3-4 weeks old. The car was clean so I QD'd the trunk and split it in half. I used some Swirl-Free Polish to remove the existing wax and also to give the surface a nice shine. I then applied the GEP followed by 2 coats of BF. At the time I couldn't tell any difference. It was on there for four days before I was able to strip the car and apply BF all over. During those 4 days, the car came out of the garage for about an hour. Plus, it was pretty overcast, and the BF was on a horizontal panel. I couldn't see any difference.
My detailing day, I decided to see how the BF reacted to the hose. It was quite interesting.
With the hose nozzle on a showering spray (some force) the non-BF side beads up a lot. Some of the water runs off, but not much. The BF side beads (but not as much as the non-BF) while the water is actually spraying. But once it stops, the beads on the BF start to run together. The water slowly sheets off the trunk. It is quite distinct how one half of the trunk has a lot of beads on it, and the other half looks mostly dry with a few stream/bead lines still. It's sort of hard to tell the trunk is split while the water is spraying, but once you stop it is quite obvious.
With the hose streaming a gentle stream (like when you try to sheet the water off before drying), the non-BF side sheets off very quickly. The stream runs down it and flys off like with carnaubas. The BF side sheets off much slower. If you run the hose over the whole thing, half the trunk is dry in a second while the other half is slowly sheeting. It is very distinct. It almost looks like the water clings to it, except if you give it time it will all sheet off. However, the surface feels very slick to the touch. It also doesn't really leave any beads left. Just a few small bead trails from where the water ran off. The non-BF side sheets mostly but still leaves some large beads/puddles (you know how carnauba does).
When I did actually sheet the car after I was done washing it, I noticed that the BF patch was almost totally dry when I got around to drying it. The non-BF side was mostly dry, but still had some large beads.
I was pretty impressed with how dry the BF part was whether the water was streaming or spraying. However, if you watch it, it looks clingy like there isn't any protection. It is possible that this is why some people have felt like the protection left their car. However, I certainly don't know what each of you experienced. The clinging of the water does look a lot like that picture Metallic Mike (MikeLS) posted a while back showing water clinging to Platinum (although I am not insinuating that Plat and BF are the same, just that his picture illustrated it well. I searched for that picture but can't find it). The BF was only on my car for 4 days in a garage and didn't get washed, so I'm quite certain it was still there. Plus, my car beads water when there's nothing on it.
I stripped the car with APC+ at a 64:1 ratio (actually, it was probably closer to 80:1). I then applied SFP to the places that needed it, and then BF GEP to the entire car followed by 2 coats of BF Protectant. There was probably about an hour between protectant coats as I ate lunch, but the wait isn't needed. I also buffed it off right away since that's what the directions call for.
Inside the garage the car looked a bit more shiney, but that was about it. Outside (having seen it for a few days) it looks better than the #7/#26. It has the same depth/darkened color (maybe a little more darkened color in the shade) as #7/#26 did. But, it has what seems like a clearer reflection and the car seems more metallic than it did before. I really like the more metallic look it gives, and I am quite pleased with BF thus far. I am looking forward to seeing what the car is like to wash when it's all BF'd, and how bugs and such clean off of it. Of course, I also want to see how long it lasts. I suspect it will go longer than a carnauba, but even if it was the same length of time, the BF would be worth it to me. It looks better and is easy to apply and remove. I will put another coat on in about two weeks and maybe try a carnauba topper to see how it looks later.
Anyway, this was just my experience with the product. It isn't meant to be representative of everyone's experience with it. But I give it a thumbs-up :xyxthumbs
