Todd@RUPES
Just a regular guy
BLACKFIRE Crystal Seal
Each spray BLACKFIRE Crystal Seal contains enough Wet Diamond Polymers to protect your paint and create that unmistakable BLACKFIRE Shine. Crystal Seal is a unique self-leveling formula that does not require additional buffing or removal. Simply wipe on and walk away. Crystal Seal is will not stain plastic and trim.
Instructions
BLACKFIRE Crystal Seal contains no cleaning agents. For maximum effect apply BLACKFIRE Crystal Seal to prepared paint or existing BLACKFIRE protection. Wash and dry the vehicle as normal. Machine polish paint defects if necessary or use BLACKFIRE Gloss Enhancing Polish to clean and prepare the paint.
Mist BLACKFIRE Crystal Seal onto the microfiber applicator pad to prime it.
Mist on to one section of the car, I. E. a fender, half the hood, a door, and spread using straight lines until a thin even coat is applied. Very little goes a long way, 4 ounces can treat up to 40 vehicles.
Apply to the next section until the entire vehicle is covered. There is no need to wipe off. Wait 30-60 minutes for all high-spots to level and cure. Try to keep the vehicle out of the elements for the next 8 hours to allow the Wet Diamond Polymers to fully cross-link.
PIC
BLACKFIRE Crystal Seal is excellent when applied to brake calipers & wheels, door jambs, interior trim (such as carbon fiber), metal trim, and windows.
If isolated streaking is visible in some areas after 60 minutes lightly wipe with a Corba microfiber towel to remove.
Instructions
PIC
