Todd@RUPES
Just a regular guy
BLACKFIRE Clay Lubricant
BLACKFIRE Clay Lubricant has a polymer rich formula allows clay to glide over the surface without sticking or scratching. It creates a microscopic barrier between the paint and the clay cleaning material. The high lubricity formula prevents loosened contamination from scratching delicate clear coat finishes yet it will not break down or degrade the integrity of the clay. Additionally BLACKFIRE Clay Lubricant is has light cleaners that remove clay residue as you work and conditions that hydrate the clay and prevent it from drying out.
Instructions
Wash and dry the vehicle thoroughly. Mist BLACKFIRE Clay Lubricant onto a small area, approximately 2 feet by 2 feet square.
Lightly rub BLACKFIRE PolyClay over the area until it is smooth and the clay glides easily.
Gently wipe dry with a plush Cobra microfiber detailing cloth.
Repeat over the entire surface of the vehicle until done.
BLACKFIRE Clay Lubricant has light cleaners that prevent the clay from sticking on the surface. If such clay smudge residue occurs, mist the area and wipe clean with a microfiber towel.
BLACKFIRE Clay Lubricant features conditioners that hydrate the clay and prevent it from drying out. This extends the life of the clay as you use it as well as when you store it. Mist the clay on both sides before placing in the storage case to keep it hydrated until the next use.
Instructions
