Todd@RUPES
Just a regular guy
BLACKFIRE Advanced Pad Cleaner
BLACKFIRE Advanced Pad Cleaner was formulated to release contamination, dirt, polish residue, ans some waxes and sealants from foam, microfiber, and wool polishing pads. Polishing pads that are cleaned often and frequently last much longer than pads that are neglected. They maintain the original performance much longer as well. BLACKFIRE Advanced Pad Cleaner attacks the grime in the pad, not the foam or nap.
Instructions
Use BLACKFIRE Advanced Pad Cleaner on a soiled pad. If the pad is freshly soiled use several sprays to saturate pad. If the pad has sat awhile and has old caked-on residue saturate the pad with cleaner.
Massage with your hands. BLACKFIRE Advanced Pad Cleaner uses non-ionic surfacants to release oil, soil, polish residue and wax from foam and wool pads yet is gentle enough that it will not dry out your skin. We still recommend wearing nitrile gloves to prevent staining or transfer to your skin.
Use a pad conditioning brush on the surface if needed.
Rinse pad clean with a hose or in a bucket of water.
If you have a rotary polisher center the pad and spin at moderate speed to aid drying.
Allow pads to dry completely before next use.
Instructions
