black spray wax and detailers
shaunls1
hey guys i have a saphire black bmw 335i coupe and i have been useing
the bf wet diamond lsp and the clear seal but im wondering about the black
spray wax and detailers thst seemed to all come out recently like the surf city and megs.
will these hide the metallic in my cars paint and are the really any better that regular detail sprays and
spray waxes im useing the surf city detail spray now and its a decent ds.
I'm a total detail spray and spray wax junkie. You aren't going to find anything better than OCW. Megs Ultimate Qwik wax is probably the best OTC stuff. Neither really mute flakes. Both do a decent job of filling in micromarring.
+1 Both great products.
The clear coat is the final original equipment manufacturers coating applied to a vehicle to protect the (base) colour coat from environmental damage, while providing both depth and a durable, glossy appearance, originally designed to protect and enhance metallic paints, but is now applied to all colours.
Claims that certain waxes are formulated and / or manufactured for specific paint types, paint colours or made specifically for a certain vehicle marquee or that they are matched to particular characteristics of individual paint systems has absolutely no factual chemical basis, it’s merely marketing hype. Any product applied on top of the clear coat needs to be transparent otherwise both the paint colour and its depth of shine will be muted.
Your theory is sound, but in reality, less transparent products make certain colors look better. Perfectly clear sealants don't look that great on black unless you like that mirror look. A rich carnauba is less than transparent, yet makes the finish look blacker than black.
Wax can be thought of as semi-solid until the solvent carrier components outgas (evaporate) these wax molecules form an egg-grate type mesh over the smaller paint molecules of the paint film surface, which gives it an optical depth. Due to this shape the reflected light becomes somewhat distorted (refraction) sometimes described as jetting (the so-called wet-look) It is a property that creates a super rich shine with incredible depth and the illusion of wetness on the surface, the better the quality and volume of refined wax the more pronounced the effect of jetting.
2005GTPinMD said:
OCW rocks - any problems with streaking when using it as a drying aid/booster? I am tempted to start doing that myself.
You'll have much less of a chance of streaking when using it as a drying aid. The only way you get streaking is if you use way too much. And then you can cut it with water.
.....or apply when the car is still wet........ :)
Dan said:
Seems to vary by color. UQW might have the edge, slightly.
OK, thanks. Heh heh, I know I'm discussing this topic to death but by the time I use up my old stuff maybe I'll know what to get! Guess I oughta just buy a bottle of the UQW sometime and see what I think.
Yeah, live a little, next time you are out somewhere, grab some! It really is a great product and it is so readily available.
UQW is good stuff.
However, I don't like Meguiar's fine mist sprayers..it's difficult seeing where you're spraying the product and any little breeze takes half of it away. Better spraying it on the towel, I guess.
