Black Plastic Grill
mynci
How do you guys deal with the black plastic grills that are found on the front ends of some cars? What products do you use and how do you apply them?
Can you be more specific? Like give us an example of a make and model so we can tell.
I at times use Stoners trim shine spray on and let dry for a long while then buff out seems to do a great job. I also have a wipeless polish in a can that is killer that I get from another supplier .
:yeah Please share your secrets with us. ;)
Off the top of my head, I can give you some examples... the newer Toyota Camry and Corolla and just about every, if not all, Mazda car.
are you talking about grained or smooth plastic:dunno
Smooth, unpainted black plastic grills. Actually, I'm considering trying Trim Restorer next time as I've had very positive, long-lasting results on the cowl. :bigups What would be the best/easiest way to apply it though?
actually on flat smooth plastic it's best to use a product like AIO, PwC, NXT, products with cleaning ability, but no abrasives, and a small amount protectant.
Trim Restorer is best on grained trim:)
For real? I always thought that those types of products would just stain plastic.
I have that egg crate grill on the mustang that you just cant get all the nooks and crannys with an applicator.I found Adams IN & OUT Spray (aerosol)easy to apply, looks great and so far durability is good
Thanks for the tips and suggestions! :) I've given some thought to using a all-in-1 type product. The only reason why I'm a little wary of that would be because I'd first have to apply it to each side of each opening of the entire grill AND then go back and remove it in the same manner. This would eat up a little more time than I would like but I'm still considering it. Now that I think about it, I'm not entirely sure if the plastic is completely smooth. It's possible that it may be textured or lightly grained. I'll have to reevaluate the plastic I'll be dealing with the next time I get the chance.
no they will clean them and you need to be gentle, you will see some color come off with them too. you can easily stain them with harsh APC's if not diluted, and by using brushes you will put scuffs and scratches in the most likely will not come out.
if it is grainy you have no choice other than to use a protectant and I like to use tooth brushes of different sizes and softness...
That's exactly what I'm talking about. :bigups Come to think of it, the same type of grill is found on a lot of Ford cars as well. One question... don't you ever find overspray to be a problem with aerosol products?
the problem with an aerosol is that it won't clean and you'll just be covering the dirt temporarily:rolleyes: yes they are time consuming to clean and a pain in the :moon: but then it's whether you want to do the job right or just get it done:dunno
My car always has plenty of wax or sealant on it so any overspray,and its not that much, is easily wiped away with a soft MF. no problems so far :headbang
