imported_Totoland Mach
This 740iL not only had soft black paint, it has the worst scratches on plastic that I've every seen! Should qualify for the Swirl Hall O' Fame!
Lower Rocker Panel. Because a rotary would probably burn this area with heat, I used my trusty Festool + cutting pad + Optimum compound and worked this area for several minutes.
Before:
After: That tool is the most versatile item in the shop. As more and more plastic is applied to body panels, it's a must have for the shop.
Rocker panel work in process:
Rear bumper: Ouch!
After: Still have some touch up to apply, but it's better.
Hood Swirls: This paint was so soft, the best correction method I found was a 3M Glaze pad and compound. The cutting pad would just create more swirls!
Getting better: I haven't polished or applied any glaze yet.
I'll add to this post as I finish up the body work tonight.
Toto
Before:
Rear bumper: Ouch!
Toto
