bissell machine..which one????
I have the 1400 model. Its works just fine for me. I will fill the water take up with hot water/solution, and wala.
I do cars every once in a while with a carpet cleaning, that is why I do not want/have the need for a 1000 dollar extractor yet.....
I do about 3 cars a month and the Little Green works pretty well. I think the Spot Bot has replaced it but I've seen the original ones on sale at Wal-Mart/Target etc. I have the heated one.
i have the non-heated LGCM, no need to get the heated one for me since i just put in hot water in the tank each time and i always wondered how hot the water gets? i saved a good chunk of change by not getting the heated one
well for 20 bucks more, I opted for the heated version of it...
I used it on my what I thought to be clean floor mat that I just cleaned using the spray, aggitate, scrub, vacuum, repeat process and this thing blew me away.....my floor mat looks brand new and it was a lot less work....definitely a must have if you dont have the need for a expensive extractor.....
no before or after shots, but once the time comes for an interior cleaning, I will get some up......
i thought these were get faded out ...any clearance or good deals on the heated lgm
I got the proheat model and I'm satisfied with it. I make sure to vac the carpet or interior good first and then use the mini extractor. I use it as a clean water rinse mostly.
I'd get the heated model for the little extra money.
The water in the heated one gets almost as hot as really hot tap water. I will also put warm/hot water in the solution tank to help the heater, but couldn't go with the non heated one because the water would cool down before I was finished with it.
And both models ought to be on sale just about everywhere. The Spot-Bot has replaced it AFAIK, so some places may be all out of the original one.
what kind of cleaning agent you guys use? I am thinking of using some diluted version of Charlie's APC. Anyone used it before?
cheers
Nick
