I have three cars I'm going to detail in the next few weeks. They are a 05' Black Honda Accord, 04 Silver Acura RSX, and a 06 Diamond white pearl Acura TL. The Accord has the most swirls...the TL and RSX have very minor swirls. I have Optimum Polish, and poli seal. I also have Sonus SFX pads, and some other pads I got from a local guy. I should be able to use the same method on all three since all hondas/acuras have a soft clear coat correct?
I don't think I need to use the Sonus restore pad SFX-1. I figured I'd use the SFX-2 Pad..which is the white one. Since it says it's for swirl reducing for regular care of paint with minor imperfections. Then I'll use the Blue SFX-3 final finish pad for the poli seal. I was thinking of topping with Natty's Red by hand.
The other pads I have are a crosscut foam polishing pad and a crosscut light cut foam pad.
The optimum polish says a final finishing foam pad will remove swirl marks at 1000-1400rpm...so would the white pad be too much? Also the rpms they give are for rotarys....what speed would that be on the PC?
How long will I need to work the OP.....as far as will it break down when it's done....or dust?
Sorry for all the questions. Just wanted to get some input before I tackle the cars.
Thanks
Thanks
