Best way to clean interior cubbyholes?
another trick for small areas is if you have a shop vac that blows. blow the dirt out first. then follow up with a good APC. the shop vac works great on vents also.
I use Meg. APC in the Tornado Black. It works really well. I've had some really bad vehicles and there is nothing like the Tornado for cleaning tight spaces.
I use a lug nut brush that ACC sells (I think it's marketed as an interior brush also). Spray a little DP interior cleaner and use the brush to agitate. If I I need to scrub a little harder input a rubber band around the bristles of the brush and it will keep its shape and allow for a little extra scrubbing power. Then I'll wipe it up with a microfiber towel.
