best polish to remove scratches and imperfections on an Infinti/nissan paint?
dpe_g35
hey,
having trouble finding best polish to remove scratches and imperfections on an Infinti/nissan paint? i've used merzerna super intensive polish, but it fully remove all the scratches(not too deep) and other imperfections, am i doing it wrong? im using a orange pad with the ultimate detailing machine.
i recommend hd final cut to start using orange pad and work it until you see the imperfections disappear, follow with orange pad using hd uno for the final polish and then seal with hd polymer . you should have no problem getting rid of the imperfections or scratches , if they are a little deep you might have to do some sanding start with 1500 grit ( depending on how deep the imperfections are ) moving up to 2000 and ending with 3000 , and then follow the first steps i listed in this response ! if you need any help pm me , good luck !
No such thing as a blanket "best" recommendation. I mostly use Optimum and Meguiars polishes and often have a stack of pads and polishes next to the car trying to find the combination that works best.
What is final cut and polymer?
BRANDEN@3DPROD. said:
i recommend hd final cut to start using orange pad and work it until you see the imperfections disappear, follow with orange pad using hd uno for the final polish and then seal with hd polymer . you should have no problem getting rid of the imperfections or scratches , if they are a little deep you might have to do some sanding start with 1500 grit ( depending on how deep the imperfections are ) moving up to 2000 and ending with 3000 , and then follow the first steps i listed in this response ! if you need any help pm me , also if you need any product contact me i am a wholesale dealer for all 3d products which makes all hd products , good luck !
