cashishift- Abrasives made for ceramic/etc. clear work fine on regular paint, they just cut faster/more. You'll find there's a huge difference between how different size pads do correction; *no way* I'd try to do that Benz of yours with any cutting pad larger than 4". I don't even do correction on my Mazda minivan with larger pads, and it has nice, medium-soft clear.
Some of us have had flaws "come back" after using 106FF via PC, happened on my DenaliXL after a *VERY* good pro, and member here, did it. He and I were both pretty surprised at the way the flaws reappeared and after I finally corrected it (for real), well...no way I'd use 106FF.
lostdaytomorrow said:
Accumulator, I am very fond of your opinions on this board and would really like to hear your suggestion to me for a better sealant under my Souveran than the KAIO...to keep my paint protected because I don't want to have to re-apply the Souveran every month or so to keep protection..
Heh heh, it seems like a lot of my advice to you might fall under the heading "you don't really want to hear this but..." so I'm glad you're finding some of it useful.
No matter *what* you put under the Souveran, the Souveran is gonna be dead pretty fast. Up to some point you can just reapply it, but after a while it leaves "dead wax" artifacts behind and things just aren't as swell as they used to be. No, it's not enough of a problem to make me use something else on my Jag, but I *did* end up thinking it wasn't the right approach for my 'vette or other drivers (I used Souveran on a white station wagon for years so I do know from using it on daily drivers
). Heh heh, this is more of that "advice you probably don't want to hear", huh? Sorry...
Anyhow, if you use a durable sealant you might be able to gently clay with something like Sonus green Ultra-fine clay to keep things cleaned up; the idea being to clean off the remnants of the old/dead Souveran without stripping off all of the sealant.
Problem for me is to come up with a good sealant for you to use this way...these days I just choose wax or sealant as opposed to layering the two on the same vehicle. Let's see...
If it were *mine* I'd use some kind of AIO after the final polishing. I'd probably go with Autoglym SRP or Zaino AIO but if you already have the KAIO you can just use that.
Then apply the real sealant.
KSG is what I use on my minivan, but it's kinda a PIA so you might not want to go that route.
Some people would steer you towards Zaino Z2.
If it were mine I'd apply a few coats/layers of FK1000P, using their FK425 QD to moisten the applicator pad. You just *might* like how the FK1000P looks/feels so well that you'll skip the Souveran, but if you *do* use the Souveran over top of it for greater depth/etc. I think you could just use the Sonus green clay after every fourth/fifth Souveran application and still end up having some FK1000P left on there. Before the whole thing needs redone it oughta be time for another full detail anyhow.
FWIW, on the Jag I use Autoglym SRP topped with Souveran and I redo the SRP about every fourth time I redo the Souveran. The SRP is easy enough to use that I don't mind doing it that way, but then again the Jag is a garage-queen.
