Bella Macchina: Bugatti Veyron Super Sport in blue carbon fiber paint correction
Bobby G
by David W. Bynon
<font size="1">Copyright©, 1999-2002, Autopia Car Care -- All Rights Reserved</font>
Some very well intentioned car enthusiasts use one cleaner as a general purpose tool for detailing. I often hear people say they use a product like Simple Green or an engine degreaser to clean everything from wheels to carpets. In my opinion, this is both dangerous and harmful to the car. After all, none of us would bathe with laundry detergent, so why would we treat delicate car surfaces with harsh chemicals?
Basic Dirt
In the science of car detailing, dirt can be classified in three ways: organic soil, non-organic soil, and petroleum soil. Not much else exists in the car world. If you can figure out the type of soil, you can select the proper cleaner. If you use the proper cleaner, 99% of all stains will come out.
Organic soil is anything that contains carbons. This includes all proteins, animal fats, body oils, mold, yeast, bugs, bacteria, animal and bug excrement, and carbohydrates. Those chilies cheese fries you spilled on the front seat are the classic organic soil.
No-organic soil is soil that does not contain carbons. This is most common on the exterior of a car in the form of water spots. Scale and lime deposits are the most common form of non-organic soil.
Petroleum soils are substances that do not contain water and will not mix with water. Petroleum soils do not have a pH factor. Petroleum soils include common chemicals like motor oil, grease and road tar. By the way, chewing gum also falls into this category.
It is also possible to have a combination of the three soils. This is a nightmare, as combination soils are difficult to identify. How do you choose a cleaner for something you can’t identify?
Cleaning Chemicals 101
The car care industry is full of chemicals for cleaning. There is no such thing as a do-all cleaner. It simply does not exist. Detailing chemicals are mixtures of different ingredients that help them do a particular job. The most common chemical functions include: surfactants, solvents, wetting agents, saponifiers, and chelators.
The word surfactant is a fancy term for any soap or detergent. Surfactant molecules are created with two compounds. One is attracted to the soil, the other is attracted to water. The chemical compound that’s attracted to water is called a hydrophile. Its job is to surround the soil. Likewise, the chemical compound that’s attracted to soil is called a hydrophobe. Its job is to break soil into smaller pieces so it can be surrounded by the hydrophile.
Every cleaner needs a solvent to dissolve soil. The most common solvent is one you might not even think of, water. Some solvents, such as mineral spirits, work great on petroleum soils, like tar and grease, and may be necessary on surfaces that might be damaged by water. Other solvents that are common in car care chemicals include dilimoneen (made from orange and lemon peels) and butyl. Although expensive, dilimoneen is a safe solvent to use throughout the car.
Chemists modify the hydrophile and hydrophobe molecules to change the characteristics of a surfactant. For example, a surfactant that is a good detergent (detergents break a soil’s bond to a surface) will not be a good penetrating agent. Penetrating and wetting allows water to surround soil so it can be removed. So, the chemist can improve the performance of a good detergent surfactant by including a second surfactant that has good wetting and penetrating qualities.
Did you know that animal fat is used in the manufacturing of soaps? Boil some pig fat, add a handful of lye, and you can make a soap bar. The same chemical process that makes soap can be used to remove fats and oils. Chemists use agents called saponifiers (basically a strong alkaline substance) to convert fats and oils into soap. Once transformed to soap, fats and oils can be washed away with water.
Have you ever noticed how much better soap does in soft water? Hard water, which is any water that contains high concentrations calcium, iron, magnesium and other minerals, thwart the cleaning ability of a chemical. The cleaner sees the minerals in hard water as soil, which uses up the cleaning agents. To combat this problem, chemists add chelating agents to their cleaners to bind the minerals so the cleaner can go after the real soil. This is why some car wash shampoos seem to hold the suds longer than others.
The Importance of Understanding pH
The term “pH� is a measurement of the relationship between hydrogen ions and hydroxyl ions. When you have more hydrogen ions than hydroxyl ions, you have an acid. Likewise, if you have more hydroxyl ions than hydrogen ions you have an alkaline.
Any solution with a water base has a pH measurement. The pH scale runs from 1 to 14. The first half of the scale (1.0 to 6.9) represents acids, and the second half (7.1 to 14.0) represents alkaline. Pure water is neutral and has a pH of 7.0. If a substance does not contain water, such as mineral spirits, it does not have a pH.
If you know the pH of a cleaner you will know if it is an acid or an alkaline. This will help you know where to use the cleaner. For example, a carpet shampoo would have a pH around 8 or 9, whereas a wheel cleaner would be between 12 and 14. Use the wheel cleaner on your carpet, and you’ll have a real mess.
Now You Know
Now that you know the basics, here are some tips to remember when selecting a cleaner:
* Organic soil is cleaned with alkaline cleaners
* Non-organic soil is removed with acids
* Petroleum soil must be removed with a petroleum-based cleaner
* Never use a cleaner that’s overly aggressive for the soil
* When in doubt, test the chemical on a hidden part of the surface to verify compatibility
Final Pictures
The Bugatti Veyron Super Sport is equipped with 'SS' 20 spoke wheels. This Super Sport's wheels
were finished with a 'Diamond Cut' two-tone and perfected by Bella Macchina.
The weave of the blue carbon glistened under the reflective finish of the finally polished lacquer.
The highly polished lacquer and clear weave made the Bugatti appear alive when walked around.
The gas fill cover, engine vents, and wheels were painted a bespoke blue at the factory and polished by Bella Macchina.
With a top speed of over 265 miles per hour, the Bugatti's front end is the proverbial 'nuke' to insects all over the world.
The swirl free sunlight reflections of highly polished and accurate paint.
The underside of the rear wing was polished as well, resulting in the accurate reflection of the hydraulic mechanism that
raises it (when traveling fast or 'armed'.)
The combination of a highly polished lacquer, carbon blue weave, and an a curvaceous body make the Bugatti Veyron
Super Sport stunning in bright light, at any angel.
Chris Schlumpf, of Bugatti USA, a professional photographer as well, sent a couple pictures of the Bugatti after
driving for several days
Jet Reception Pictures- Immediately after detailing the Bugatti Veyron, Bryan Burnworth hoped on a plane to return home.
I drove the Bugatti to the Jet Center Reception close bye were it was to be the star of the show.
Final Picture-
Special Thanks to:
Bryan Burnworth- Peach State Detail, LLC- for flying down from Georgia, working 11 hours, and getting straight on a plane right after he finished. Up until the last minute we did think Bryan was going to make it. Then he showed up, grabbed the hose, and started spraying.
Mike Pennington from Meguiar's- For recommending me for the job and setting the entire thing up. Thank you for the trust!
Bob Willis- Auto Concierge and Richie Carbone- Richie's Custom Detailing- for volunteering to help out due to the time crunch. Unfortunately the Tampa International Airport was apparently pressuring Bugatti USA about having too many people walking around in a secured area. Irregardless the offer was awesome!
I hope the write-up was enjoyable, comments or critiques welcome!
O m g
The finest write up I have ever seen, with cabon fiber backdrops and paint thickness diagrams from multiple angles! absolutely awesome. O and the detailing job speaks for itself, with Todd and Bryan I think most who visit here would already know how it would look --flawless :notworthy:
A detailing job all in a class by itself. Congratulations Todd! This has to be the new Gold Standard. Definitely one for the record books!! A show stopper indeed.
Best,
Jose
ultimate wax
I've seen sealant/wax for high heat applications, as long as it is fully synthetic, a sealant will be durable enough for wheel applications I assume. any input is appreciated thnx
I can't think of too many better ways to start my morning! LOL.
What an awesome write up. The pic-to-grams showing the stages of polishing and the explanations are text book material. How lucky we are to have to break down the processes so that even guys with my experience or lack of it can learn from it.
I really enjoyed looking at the process and progress. The CF shots are great. Not easy to catch that detail in a photo. Congrats on the reccommendation from Megs- that about says it all.
It is a kool car and I can apprecaite it for the marvel it is! Must have been fun to start up/drive.
Truly a great write up, I enjoyed every bit of it including the commercial shot of the NXT Glass Cleaner. I saw that and said, commercial. then I read your caption. with that being said, I think I will pick some up! If it is good enough for the Super Sport, it will be fine for my Infiniti! LOL.
Thanks for taking the time to post in such great detail. I really do appreciate that you list the products, pads/polish combo's and point out how each works in the 3 step process. Really helps out Weekend Worriors like me learn.
Have a great weekend.
Supremo!!!!!!!!!!!
Muy Bella la Bestia...........!!!!!!!
Maestro Todd , you have brought each and every detail beautifully.....
Marvelous write up ...........!
:wizard:
Todd,
This just absolutely blew me away. Your detailing is in a class of it's own. There is a reason that you were chosen to do this amazing car. You and Bryan did an outstanding job of restoring this piece of art. You both deserve a huge :thumbup: for the job you did.
Now, onto the write up. There are so many great posts here on TID, with truly spectacular results. However, no one, and I mean no one does a write up quite like you Todd.
Thank you so much for sharing this with us.:notworthy::notworthy::notworthy:
Todd, do you have a publishing staff on hand? Trying to decide which is cooler, the car or the write up. Ok, the car....but the detail you put into the write up is amazing. Nice work!
I suppose this should put an end to all Show and Shines
Tremendous job on both the detailing and write-up. Congratulations Todd, I know this is the stuff you live for
Trouble :-B
Interesting car.
Very novel write up. The fact is the majority of steps apply to DD as well as the Buggati using products all of us can pronounce and purchase readily. I appreciate you sharing these "secrets".
I was wondering when the write-up was coming, and now I see the reason for the delay. Well worth the wait. Amazing car, amazing work and amazing write-up. :clap:
