BE Honda GX160 5.5HP
Honda in general are great motors..but a bit more info about what you want this for would be helpful
Yes it is one of the best in that horsepower range. I'm assuming you are looking at using this for a pressure washer or other type of pump. When maintained it will easily outlast it's more commonly found non commercial competitors (B&S, Tecumseh etc.) by two to three times. I make this claim with some 30 years behind me fixing small engines. You will likely go through pumps long before the engine lets you down. Great go-kart motor also.
2000 PSI pressure washer to hook up to my 200 gallon portable water tank to wash cars. They are asking $200.00 for it.
I assume that at this price you are looking at a used engine? A motor like you have described will undoubtedly handle the work you have in mind for it. Pump will ultimately determine pressure.
