[B]which pad is for PC 7336[/B]
bsk_500
Porter cable 7424 6.5 inch polishing buffing pads
will any of these foam pads fit my PC 7336? can i use the same foam pad right after i'm done with my first job? for example, once i'm done with polish i use the same foam pad on the wax job. i am hoping that two foam pad will be enough for paint cleaning, polishing and waxing. thanks in advance for your reply.
yes the pads will fit, you just need a backing plate
no you will want clean pads for each product
and you will want differnt cut pads for cutting/polishing and waxing
how long does foam pad last? i will only be using on my wife's car and mine, and i will polish & wax as everyone here recommand. how often should i polish and wax? which should i do more, polish or wax? or should i clay, paint cleaner, polish and wax all together? thank you all in advance.
