Autopia-CarCare.com 15% OFF and FREE Shipping Summer Care Sale TWO!!!
Todd@RUPES
Just a regular guy
Promotion has ended!
Autopia Summer Care Newsletter Part 2 of 3
Tips for Protecting Your Car's Exterior in the Summer from Autopia-CarCare.com
Summer is the season for fun and relaxing. It also happens to be when our hemisphere is closest to the sun, resulting in long days and hot temperatures. You wouldn’t go to the beach without sunscreen and you shouldn’t leave your car’s exterior surfaces unprotected. In this, the second of three Summer Care articles from Autopia-CarCare, we will look at how to quickly protect the exterior surfaces of your vehicle. With these tips, you will be able to spend more time driving and enjoying your summer!
Summer temperatures can be scathing. The heat limits the time you can enjoy working on your vehicle. The long days mean waking up at dawn or waiting until dusk to enjoy more tepid temperature. Even then, if you take too long you may run into problems. Early risers are quickly met by the first scortching rays of sunlight. Night owls will find that dusk fades to complete darkness in no time. Autopia-CarCare.com carries several products that will make your summer protection easier than ever, when you need it the most!
Wipe On and Enjoy!
BLACKFIRE Car Care, Optimum Polymer Technologies, and Ultima offer advanced wipe-on and walk away paint sealants that can be applied in as little as 15 minutes to most cars. These advanced paint protectants are based on self-leveling polymer technology that does half the work for you! This means less time spent sweating in the summer temperatures and more time actually enjoying them.
A look at some of our popular Wipe On and Walk Away Sealants:
BLACKFIRE Crystal Seal creates an advanced polymer film that outlasts other spray sealants with half the effort. BLACKFIRE Crystal Seal is a paint sealant that offers incredible protection and longevity for all paint finishes, glass, plastics, and metals. Just drops of this clear liquid produce a tough barrier that resists contamination, moisture, and UV rays. Hyper-concentrated BLACKFIRE Crystal Seal packs the power of cross-linking Wet Diamond polymers in every drop.
Optimum Opti-Seal features incredible science! The hyper concentrated polymer sealant begins cross-linking as soon as it hits the paint. Opti-Seal flashes almost immediately to leave a polymer film on the paint. Opti-Seal is not a short-cut product. It is a state-of-the-art, stand-alone spray sealant that provides real, durable protection for paint, plastic trim, and wheels. This is a last step product, not a maintenance product. After polishing, apply Opti-Seal and walk away. Opti-Seal is the only paint protection your vehicle needs.
Ultima Paint Guard Plus, containing Polycharger Wax Booster technology, is the longest lasting, clearest and easiest paint protection you can apply to your car. This product takes about ten minutes to apply to a clean, dry vehicle. Simply wipe on and walk away. No buffing required.
Proper Prep Work:
In order to get the best protection and performance your automobile should be ready to accept the sealant:
  • Wash all exterior surfaces thoroughly to remove any loose grit, dirt and soiling. For tips on how to wash your car in the summer months review the previous Autopia Newsletter.
  • Inspect the finish for bonded surface contaminates. If the paint does not feel smooth use detailing clay to deep clean the paint. For more tips on using detailing clay visit the Autopia-CarCare.com How To Guides.
  • If the paint is worn or lacks shine use the appropriate pre-wax cleanser to restore gloss: BLACKFIRE Gloss Enhancing Polish, Optimum Poli-Seal, or Ultima Paint Guard Prep Plus.
Proper Technique
Applying a wipe-on walk away sealant could not be easier. Each product comes with a specific applicator suited to proper application. Apply in the shade or in shelter, out of direct sunlight, to reduce the chances of product smearing.
  1. Lightly mist the applicator with one spray of product.
  2. Using a sweeping motion, apply a fine mist of product to the body panel. Large body panels such as hoods or tonneau covers should be treated in two different sections.
  3. Spread into a thin, even coat over the panel using straight, overlapping motions. Wipe on, walk away paint sealants are hyper concentrated. Use as little product as possible to cover the surface. Work lightly into the surface.
  4. Apply to paint, glass, headlights, and taillights. You can even apply to wheels if they are clean.
  5. Much of the sealant will appear to melt into the surface, that is okay. Remaining wet spots may linger for five to fifteen minutes. After fifteen minutes, lightly buff any wet spots with a clean microfiber towel to even out the coating.
  6. Allow the sealant to fully cure for several hours before exposing to rain, water, or extreme temperatures.
Protect Your Tires and Trim:
With your paint well protected it is time to focus on your tires and exterior trim pieces. Excessive sun exposure can prematurely age rubber, plastic, and vinyl. Spraying silicon laden dressings on these pieces will temporarily restore their appearance but offers little real-world protection. To protect yourself from sunburn, you use sun block, not baby oil! Autopia-CarCare.com offers many high-quality tire and trim protectants that will make these pieces look great while offering valuable protection to keep them looking new.
A look at some of our popular Tire & Trim Protectants:
303 Aerospace Protectant has been a top choice for a long time and for good reason! It is like SPF 40 sunscreen for your tires and trim. Regular use prevents UV-induced sun fade on a multitude of materials. 303 Aerospace Protectant does not change the appearance of the treated surface; it's not shiny, sticky, or greasy. For the best results, protect new materials immediately with 303 Aerospace Protectant from the start. With regular use, all your belongings will retain their like-new appearance!
Ultima Tire & Trim Guard Plus is a new polymer coating that can be applied to most flexible surfaces, including vinyl and rubber, as well hard surfaces, such as plastic and metal. This amazing product coats, seals, protects and beautifies. No ordinary “dressing” lasts as long or protects as well against pollution, ultraviolet light, road salts, harmful ozone, creosote and more. This amazing trim sealant lasts for months, not days or weeks.
Wolfgang Exterior Trim Sealant is the result of the marriage of German and American technologies. It is made from a special blend of clear polymers, UV blockers, and a rust inhibitor that shields exterior trim from the sun and weather. Lots of products "dress" rubber and vinyl trim, but few offer a natural looking finish plus real protection. It is water-resistant and long-lasting.
Tips and Tricks for Getting The Most From Your Trim Protectant:
For exterior trim and tires we recommend applying according to the manufacturer’s recommendations. The general guidelines below will help you achieve the best performance and longest lasting protection:
Coming Soon
In the third and final Summer Care Newsletter, Autopia-CarCare.com will cover how to treat and protect your interior against the heat and sun damage. Your interior is covered in delicate surfaces such as leather, rubber, plastic, and vinyl that can fade quickly and dry out when exposed to the summer climate.
JOIN THE AUTOPIA NEWSLETTER!
Join the Mailing List at Autopia-CarCare.com for more special offers and great tips. Sign up on the home page!
Quick Summer Tip
A Carnauba For Wax Lovers In The Sun
For some the liquid wet shine created by a carnauba paste wax cannot be beat.They are notoriously finicky when applied in high heat. The idea of applying a carnauba wax in the sun has garnered more than a few comments and looks of disbelief at car shows. Autopia-CarCare.com offers a wide selection of carnauba waxes for every enthusiast. The Natty's range of carnauba wax from Poorboy's World can be used in direct sunlight while still delivering that liquid shine that is so coveted. Grab your sunblock, your Natty's carnauba wax, and your sun glasses. You will need them to protect your eyes from the shine.
Poorboy's World Natty's Red Paste Wax
Poorboy's World Natty's Blue Paste Wax
Poorboy's World Natty's White Paste Wax
