Audi A6 s-line , black
CosminTX
ProReflection
here is what i start with : spiderwebs , swirlmarks , light holograms. a 70%-75% improvement after 2 steps.
car was wash with onr and clayed.
i use pc with meguiar`s 105 on 5.5 orange pad and meguiar`s 205 on sonus white polish pad, protection opti-seal.
on inside i use optimum leather protectant on vinyl and leather, wheels got optimum car wax and endurance tire gel.
corrected, or at least better than what i start with
nice interior!
nice interior fo sho. I'm surprised you got such a low result on the outside. What machine did you use? Did you push hard while you did the compounding?
i was frustrating too , but when people tell you one step is enough and is an black car "it's 3 years old, so not in bad shape" and u get there and is all spiderwebs , holograms and swirlcity.... u do what u can!
i use g110 but a makita was probably better.
i use g110 with 105 on 5.5 orange pad , with the first 3 passes on pressure speed 6.
i follow with polish pad , 6in white sonus pad and 205 wit first 2 passes on pressure speed 6.
the car looks times better then what i start with.
i definitely see the improvement. considering the fact that it was a diy job you couldn't have done better. was the interior customized?
the problem with the s line is its maintenance, reading the audi a6 service manual, i could not understand a thing.
maintenance u kidding me? i put 40k miles in 2 years on my audi ,no problems at all. i do the oil change myself , some seafoam treatment , sparkplugs ,brakes , clean air filter, the car runs like new.
get elsawin , or bahn or bentley manual and u all set. true mine doesn`t have turbo 2.7T may have more maintenance :woot2:
With the exception of a modified suspension, the Audi "S line" is essentially just the A series with a trim package.
The maintenance is the same. The composition of the paint is the same.
I think 75% is right in the range where he should be using a PC on a HARD *** Audi clear. I have a 01 A6 and the clear is just a rock lol
Great job on the correction!
