I've got a gallon of ARO that I've used a little bit. So far its worked great. I just bought a gallon of Megs APC. Seems that the APC can do most everything that the ARO can but for a lot less $$$.
The only thing I'm not sure about between the two is ARO is supposed to be good for vinyl/conv tops.
Are there any advantages or reasons I should order ARO after I run out instead of APC? Is the ARO safer on clear coats?
