Black to give the mysterious and white to give a symbol of noble. TaylorMade launch of TaylorMade R11 Driver, adjust to a white head and innovative 3D technology to subvert the football sport, R11, is rapidly becoming the preferred driver of global PGA golf tournament. r 11 driver is designed to serve an order to the achievement farther the ball away from wood. With the R11 3D regulate technology, you can always adjust the loft. Several faster swingers make aggressive swings without fear of a hook due to clubface adjustability; many testers hit it higher than normal. It is more playability.
In TaylorMade R11 series, TaylorMade R11 Irons with the weight removed from the clubface has been shifted low and back to create a higher launch angle, faster ball speed, increased distance and more forgiveness. They are disciples of both the Burner 2.0 and Tour Preferredirons.TaylorMade R11s Driver The result is comparable launch, ball flight and length to the Burner 2.0, as well as 15-yard distance gaps between clubs. Whether it is driver, or irons, TaylorMade gave us presents not the same as golf skills, they are worth having.
