Applying KLASSE using a PC - Which Applicator To Use
Either will use too much product and I think both would be too harsh to apply with a PC. I would use a black/grey pc pad to apply Klasse Glaze.
I always apply by hand, you'd waste far less and it doesn't seem like I would save that much time anyhow.
On a severely oxidized finish, a PC with a polishing pad and AIO works quite well. If the paint is in decent condition to start with, applying by hand is probably faster.
Since I have never used the SG, and he only asked about AIO, I'll leave that alone.
Charles
I always use the PC to apply the AIO, it's fun, easy, and leaves a terrific finish for the SG. It might waste a little product, but what the heck, we're doing this for fun, right?
On my Pewter Z-71 GMC, I haven't even used the SG yet, I just re-apply the AIO every 4-6 months with the PC.
I use the PC/white foam pad to apply AIO and follow up with SG applied with a grey foam pad (both DVC foam), usually about every four months, suns is pretty strong here.
justadumbarchitect
White pads, grey pads, black pads???
How about using the type of pad instead of the color? Not all manufacturers of pads use the same color system.
Cutting pad, polishing pad, finishing pad, these mean something to me. White, grey, black, orange, red, yellow, beige, are just colors.
Charles
I used a polishing pad to apply the AIO. On an older car I think it is definitely worth using a PC but on a newer car I believe doing it by hand uses less product, just as quick and works just as well as a PC but you could get by with a finishing pad on the newer car. Just a matter of user preference and how hard you need the amazing AIO to work. However, I would most definitely recommend doing SG by hand.
I do as much as I can by machine, started doing it that way back when serious shoulder injuries made hand-application impossible. Now I STILL do it that way. *IMO*, the PC goes over each area a lot faster, more often, and more uniformly than my hand would. And *I* find it a lot easier to move the PC back and forth, easier to use my whole body, which can be important when doing a big job.
For AIO, a foam POLISHING pad works well. This includes Griot's orange pads, CMA/Lake/TOL white, and Meg's yellow.
For some tough areas, like the "gravel guard" (textured paint, often with a satin/flat black finish) on some cars' rocker panels, I use a CUTTING pad. Note that many cutting pads are NOT, in and of themselves, so abrasive that they will mar modern paints, at least not when the pads have a product like AIO on them. I used AIO with a cutting pad on the black painted rocker panels and black plastic lower bumper sections of my Audis- with GREAT results.
For SG, use a foam FINISHING pad. Be especially careful to put it on thin, this can be sorta tricky when applying by machine. If you get it on too thick, give it extra time to dry, use a damp MF for the first wipe, and maybe also use some QD.
IMO, there are worse things you can do than waste a little product. By hand, by machine, do whatever YOU like doing.
“White pads, grey pads, black pads???
Cutting pad, polishing pad, finishing pad, these mean something to me. White, grey, black, orange, red, yellow, beige, are just colors.�
The foam pads I use are “Durofoam Variable Contact “ (DVC). The colour indicates it’s ‘cut’ and what it’s normally used for. They are available from Classic Motoring Accessories, and are a custom blend of thermally reticulated polyurethane with a 99% open cell structure. These foams are created specifically for compounding, polishing and finishing; this foam allows air to circulate through the pad to reduce heat build-up.
I hope this answers your question…/
justadumbarchitect
This got 'missed out' of my post-
Pad Colours:
Yellow: Cutting
White: Polishing
Grey: Finishing
justadumbarchitect
Thanks for the pad/color clarification.
I happen to use Meguiar's PC pads and their cutting pad is maroon, their polishing pad is yellow, and their finishing pad is tan/beige.
Charles :wavey
As you can see from my 'signiture'(justadumbarchitect) I'm not a professional detailer and I had thought that there was a universal colour system to enable recognition between pads.
I now see that it differs from mfg to mfg.
Jon:
You will find that you can't depend on what you think you know, even within product lines by the same manucturer.
Case in point.
Meguiar's
QuiK Detailer - A quick detailer :doh
Quick Detailer - A fairly aggressive cleaner/wax
Final Inspection - A quick detailer that is body shop safe
Final Detail - A quick detailer that isn't body shop safe
No doubt, all are good products, but sometimes it is a little confusing sorting out the correct names.
With Meguiar's, read the description and the instructions beforeyou buy the product. If in doubt, call them. 800-545-3321
Their reps are not nearly as bad as some people seem to think.
Charles
(Just a dumb retired peddler)
