Brian_Brice
ive been using my sonus blue pad and pc to apply cg's butter spray and a few other spray waxes, any harm in doing so with jett trigger? wouldnt that use less product?
VaSuperShine said:thanks josh,
yeah im just tryin to save as much as i can, i do use sparingly and normally dont overapply anything i was just curious really if there was a benefit results wise and saving product. havent even got my order in and im trying to stretch my buck already lol.
Applying the AJ with a PC and spritzing AJT for removal seemed to work good on this car. Then we did a 89 GMC the next day. Removed oxidation with PG/RMG mix. Then the same JW process as above. The hood got very cloudy in one area. Nothing would remove it, not prime, IPA wipedown, ect. The hood just got worse with everything we tried. Ended up doing a IPA wipedown of the whole hood then repolish with IP/RMG. Applied Z1 and Z2pro without any problems to the hood.
Darren F said:when you say you removed it with AJT, do you spray it onto the MF or directly onto the car and then remove it?
