Anyone use the Rupes LHR 12e for sanding?
AtoZDetailing
I know it's still a new product, but has anyone had any experience using the 12e for sanding? I have a '59 caddie coming up in a few weeks and I am thinking about placing an order for one.
Cheers!
I have been wanting to try the sanding discs that came with my duetto kit but kind of nervous to do so but mostly since I have never tried this before. Yet to find a beater that wants to let me experiment.
Those foamy sanding disc ROCK on a duetto. Both of them mini and 12e. I've also used my 15 and 21 for sanding a many time. Just know what your doing because they work really fast. 12e is gonna be more forgiving but still works much faster than small stroke machines. I really like it because it goes so much faster.
Great idea practicing on a test vehicle first. :bigups
Thanks for the feedback guys. I'm very familiar with sanding with a DA so I think i'll try out the Duetto. I'll let you know how it turns out!
It used to be that "small stroke" machines were only used for DA -sanding. By small stroke, I mean less than 5mm orbits (or 3/16ths for us standard unit people). The reason was large stroke machines, because of the longer "curly que" and faster rotation were thought to create pig tails scratches.
However, in recent years we have seen a shift to larger stroke machines, used at lower speeds... Why???
The large stroke (12 mm in this case) does a better job at cleaning the area under the sanding disk. As you sand and remove material, it piles together in that small space between grain of the sandpaper and the paint. A small stroke rubs this built up over the same area quickly, almost burrowing it in. However a larger stroke moves the disk along, as well as allows more of the sanded material to be ejected.
The result? Faster sanding and a more uniform result! The best of both worlds.
I start around speed 3 and move up from there. With the large stroke you don't want (nor need) a lot of pad rotation. Let the large stroke do the work for you!!! :rockon:rockon:rockon
Todd, your never-ending research is why you are considered by most (myself included) to be one of the best, most well rounded detailers on the planet. The fact of the matter is you the research that others are too lazy to do, so you can explain coherently the reasons behind a major shift within the industry, and the underlying technology behind it. Well done, sir, on this, and all the science/tech related work you do.
:yourrock
:yourrock
Thank you. I have been very lucky to work with the best teachers in this industry. I cannot take credit for their knowledge but hopefully I do a fair job explaining it!
