Renovating Leather:
Rejuvenator Oil - known for its ability to soften even cardboard hard leather, a complex blend of animal oils and proteins, Collagens and other beneficial ingredient, it will not stain or discolour leather. Simply massage into the leather with your hands, and let it be absorbed into the fibres, its' unique capillary action forces the oils and proteins into the leather and the dirt out.
Prestine Clean - does not contain any harsh chemicals or petroleum distillates to dry and destroy fine leathers, contains a conditioner that cleans and conditions vinyl, even rubber trim pieces. Use to clean leather after application of Rejuvenator Oil has done its job or as maintenance cleaner.
Application Methodology:
â€Â¢Apply cleaning solution (Water /Woolite or Dreft 6:1 or stronger) on to an applicator pad and apply to one area at a time (i.e. a seat back).
â€Â¢Use a Microfiber waffle weave towel, rinse in warm, clean water and wring out as much moisture as possible, fold the towel in half and then half again
â€Â¢The oil will work better if you first warm it in a microwave, and also warm the leather surfaces (in the sun, with a hair dryer or with the vehicles heating system) this allows the oil to permeate deeper
â€Â¢Apply 3-4 ounces of the Rejuvenator Oil onto each of the seats with a light to medium pressure.
â€Â¢Ensure complete coverage of surfaces, especially the seams
â€Â¢Let the Rejuvenator Oil remain on surfaces 8-24 hours for best results. Avoid driving during cure period.
â€Â¢Once the Rejuvenator Oil has been on the surfaces for at least 8 hours, you will see the grime that has lifted come to the surface, it may be a whitish haze, and any tacky residue on the surface is dirt or pollutants that have been forced out of the fibres.
â€Â¢Put the Prestine Clean in a clean mist / spray bottle
â€Â¢Spray lightly onto a 100% cotton DF Microfiber towel, apply to leather surfaces with light to medium pressure, for tough dirt gently agitate the surface with a boar's hair cleaning brush. This removes stubborn grime and will not harm the leather.
â€Â¢Wipe leather surfaces with a damp Microfiber cloth, turn towel to clean fold surface as necessary
â€Â¢Finally buff all leather surfaces with an Autopia Concourse Buffing Towel
â€Â¢If you require a softer finish, repeat the above Rejuvenator Oil process.
JonM
