Aniline Leather; Cleaning and Care
togwt
The Old Grey Whistle Test
Research
Information regarding the care of leather is scarce, often contradictory, misleading, or simply wrong. Misinformation can lead to inadvertent damage to your vehicles leather upholstery; my goal is to present clear, concise, accurate information.
There is a great deal of conflicting information on leather care being put out by leather experts themselves who use baffling pseudo scientific techno speak as another marketing ploy, which makes it difficult to find a definitive, unbiased answer. It had always confounded me that such a simple subject has been made into something so complicated.
After various meetings and discussions with leather tanners, their chemists and fat liquoring formulators and many leather care product manufacturers I’ve gained an understanding of this versatile material on both a practical and scientific level.
I have always thought that the more facts and information you have at hand the easier it is to judge what information you are being given. After all, how can you fully understand and properly use any product unless you have all the facts? In the final analysis; it’s your vehicle, your hard earned money and your choice
Here is one definitive truth –you are dealing with the leathers finish, not the hide itself.
Vat Dyed (Aniline) Leather
Quality manufacturers use only top grain leathers because they are by far the strongest and most supple part of the hide and, therefore, best suited for upholstery. After the top grain leather has been removed it is bathed in a chemical solution which stabilizes the hide and changes it chemical structure so that it will not deteriorate.
Aniline is an immersion dye method not a leather type per se. Vat dyed leathers are submerged in large, slowly revolving drums, Aniline dyes in various colors may be added to the drums at this stage, while the hide is absorbent. They are tumbled and during that process, the colour will generally permeate throughout the hide. This is the step in the tanning process that has been so improved in recent years. The tanning procedures used now are permanent and create a product which will last indefinitely. Previous methods employed vegetable derived tanning agents and were not as effective in preserving the leather.
If correctly done, aniline dyes are permanent and will not rub off or "crock" after the leather is in use. Dyeing should not be confused with pigmentation of adding color to the surface of the leather.
It is often used in prestige European automobiles; Aston Martin, Audi, Bentley, Ferrari, Jaguar, Lotus, Lexus Range Rover and Rolls Royce, US Cadillac and high-end German automobiles such as Audi, BMW, Daimler AG and Mercedes-Benz.
Micro Pigment Cleaning and Care
Micro Pigment (automotive-grade aniline) is the second most popular leather used in automotive upholstery, micro pigment is often protected by a micro-thin urethane, which is sometimes pigmented (colour) hence the name, sometimes perforations are added.
Other so-called aniline leather (Milano, Silk Nappa, Valcona (Audi) Boston, Baseball, Dakota, Montana, (BMW) Chaparral, Range Rover Vogue are examples of micro pigment leather. Transparent, not even milky or translucent dye is added to an opaque medium, the opacity y remains, although some colour is added, and the net gray-equivalent brightness is always reduced, because a dye can only absorb light.
The leather used for automotive upholstery varies from leather industry standard descriptions and although the names are similar the type of leather, pigmentation and finish are often very different. Genuine Aniline leather is very rarely used for automobile upholstery as it is not rigorous enough to stand up to the conditions it would be subjected to.
Using advanced micro pigments this finishing technique leaves the leather feeling like pure Aniline, yet the colour is even and the pigments provide incredible durability not found in Aniline leather. These come in several variations and are usually full grain leather with a very fine (micro) coat of pigment to create the colour or effect and then sealed
Generally speaking micro pigment style leathers come in very earthy natural colours, incorporating a small quantity of pigment (a thin clear sealant that provides a uniform colour and affords some protection) but not so much as to conceal the natural characteristics of the hide so it will still retain the soft hand or patina of Aniline leather. This type of leather is also used for perforated leather finishes.
Unprotected Aniline is rarely used for automobile upholstery; although Aniline is an immersion dye method not a leather type per se. Micro Pigment (automotive-grade aniline) is the second most popular leather used in automotive upholstery, micro pigment is often protected by a micro-thin urethane, which is sometimes pigmented (colour) hence the name, sometimes perforations are added.
Ford F-Series King Ranch, Chaparral or Castano leather, it is important to understand that the seats were not intended to retain the pristine factory finish, they will weather and gain character beginning almost immediately, they are also subject to photo degeneration (fading) very quickly.
Aniline leather is a term used by the auto leather industry to describe a Micro Pigment leather that has a thin urethane layer of pigment coating, which provides an even colour and abrasion resistance. As opposed to the mislabelled Aniline leather, this will absorb body oils and moisture and would be subject to abrasion unless it has been treated in some way.
More often used for automotive upholstery as it is more durable than aniline whilst still retaining a natural appearance. Aniline leather which has received a surface coating containing a small amount of pigment in the base coat, this surface coating helps impart greater stain resistance. The increased durability is provided by the application of a light surface coating which contains both pigment (colour) and an anti-abrasion additive, this ensures consistent colour, imparts some stain resistance and helps with the abrasion of entering and exiting the vehicle
Using advanced micro pigments this finishing technique leaves the leather feeling like pure aniline, yet the colour is even and the pigments provide incredible durability not found in aniline leather. These come in several variations and are usually full grain leather with a very fine (micro) coat of pigment to create the colour or effect and then sealed
Generally speaking micro pigment style leathers come in very earthy natural colours, which has been aniline dyed or stained, which may incorporate a small quantity of pigment (a thin clear sealant that provides a uniform colour and affords some protection) but not so much as to conceal the natural characteristics or feel of the hide. Other colours (i.e. gray, black, etc) have a pigmentation coating added. Transparent, not even milky or translucent; added to an opaque medium, the opacity remains, although some colour is added, and the net gray-equivalent brightness is always reduced, because a dye can only absorb light.
This leather is also used for perforated finished leather. A full aniline immersion dye is one method of tanning to achieve a desired, natural looking hide or leather. Because the finish is transparent and shows the natural markings of the leather, only top quality hides can be used. The aqueous (water- based) pigmentation allows for evaporation and replacement of moisture (hydration) staying cool in the summer and warm in the winter.
Micro pigment (unprotected Aniline is rarely used for automobile upholstery) leather is absorbent, which means that any spills, body oils etc will soak into the leather hide. Use specific aniline leather cleaner that that will clean the surface of the leather, without being absorbed, or force the soil into the leather. A foam type cleaner is ideal for this type of leather.
Identifying characteristics
Generally speaking aniline style leathers come in very earthy natural colours, and is coloured all the way through with a transparent dye. It is absorbent and has a random shade colours and grain pattern, lightly scratch the surface to see if it reveals a lighter colour.
The water-drop absorbency test- water drops will permeate the surface and darken its colour (temporarily)
Absorbency rate – Medium High
Micro pigmented leather is very absorbent, which means that any spills, body oils etc will soak into the leather hide. It should be routinely cleaned to remove light dirt and dust by using specific aniline leather cleaner that that will clean the surface of the leather, without being absorbed, or force the soil into the leather
A foam type cleaner (Leather Masterâ„¢ Foam Cleaner) is ideal for this type of leather along with. Leather Masterâ„¢ Soft Touch (ex Vital) and allow to dry for approx 20 minutes, finally using a clean dry 100% cotton micro fibre towel buff to a matte sheen.
In addition to regular cleaning to remove abrasive debris and oils, leather requires regular replacement of its moisture (re-hydration) by regular use of a damp 100% cotton micro fibre towel
Micro pigmented leather is moisture sensitive, so avoid the use of liquid, oil-based or wax-based products as they may negatively affect the evaporation and hydration moisture balance. Aqueous (water- based) products will help to hydrate the leather and maintain necessary moisture (Leather Masterâ„¢ Soft Touch (ex Vital). The oils secreted from your skin are slightly acidic and may cause the Aniline leathers pigmentation to lose its colour prematurely, taking away the effect of a premium leather interior. Removing these oils is paramount to leather care, but limiting the amount of bare skin you expose to your seats and interior is a great way to prevent discoloration. This type of leather can be renovated with a pigmentation coating
Removing Stains
• Surface dirt and dust – use a soft brush, vacuum and then use a clean, damp cloth
• Spills – use a dry 100% cotton micro fibre towel to absorb liquids, and then wipe clean with a damp 100% cotton micro fibre towel.
• Stains – use a mild leather cleaner (test on an inconspicuous place before use) using very little pressure and do not ‘scrub’ to remove
• Water marks - wet the whole panel while the area is still damp and this should then dry evenly. However if the water has dried and permeated the leather leaving a hard edge no amount of cleaning will resolve this.
• Oil stains – should be removed immediately, if allowed to permeate it will stain. Leather Master Leather Degreaser is applied through a spray. It dissolves the oils and transforms them into a powder that is more absorbent than the leather. This powder is what is wiped off, cleaning and degreasing the leather. Allow the white powder to dry fully. If the powder is drying to a yellow colour, it means that there are still a lot of oils in the leather.
For resistant strains specific cleaning product are available, but be aware that certain stains may not be removable, i.e. dye transfer from leather belts and jeans, coffee, penetrated sun tan oil, food sauces, citrus fruit drinks, etc are especially difficult to remove. On this type of leather anything that is allowed to permeate the leather may stain it permanently as it is not possible to clean out of leather.
Clean accidental spills right away, do not allow liquid to soak or ‘heat set’ into the leather. It is very important with this type of leather to use a protective aqueous (water- based) type protection product, which will inhibit dirt and body oils etc from being absorbed into the leather in the first place; these can then be cleaned from the surface easily. Aniline pigmented leather fades at a faster rate than protected leather, so ultra violet (UV) protection is of paramount importance.
Three Step Micro pigment Leather Care
Simple cleaning, hydration and protection are the three steps that will prolong the life of Micro pigment finished leather. Always pre-test the product on a hidden area. Shake the foam container thoroughly. Spray the product at a distance of 12 inches from the leather to one section at a time, and allow product to remain in place for approximately 15 to 30 seconds.
Micro pigment leather doesn’t require conditioning or rejuvenation; always keep in mind that you’re dealing with the finished coating on the leather and not with the leather hide itself
1. Clean – there are two cleaning-related factors that can cause your leather to wear prematurely. The first is dirt, and the second is oil, combined they become very abrasive, as dirt / grit and subsequent friction cause the finish to wear
Remove surface dirt and dust, cleaning the seams periodically is important as dirt / grit will abrade the stitching causing them to fail, prise them apart, then use a soft brush, vacuum and then use a foam cleaner, one section at a time, and then finally wipe off with a clean, damp 100% cotton micro fibre towel
The advantage of foam over liquid is the minimum amount of moisture, very important for cleaning absorbent and moisture sensitive leathers.
Use foam cleaner, which should be given dwell time and then gentle agitation with a medium stiff bristled brush to get the product into the materials surface, the low moisture content of foam can then be easily rinsed and the surface dried. Remove excess product and debris with a clean, damp 100% cotton micro fibre towel. If the foam is allowed to dry the soil will be re-deposited to the surface. Check the results and repeat process as necessary
For heavily soiled areas use a foam cleaner (Leather Masterâ„¢ Foam Cleaner) that contains a surfactant that will lift dirt and soil, allow react time to do its work and then use a soft brush to agitate and loosen the dirt (Swissvax Leather Brush) especially on light coloured leathers; this enables the cleaning of the micro pores and creases and lifts the dirt out and reveal any further work that needs doing (dye transfer, stains, etc)
2. Hydrated – when leather tanner’s talk about conditioning leather they are referring to its moisture content, re-hydration is used to restore or maintain fluid balance (transpiration and evaporation of moisture); not the replenishment or replacement of the fat liquoring, oils and / or waxes.
Repetitive heat cycling causes the leather to lose moisture, resulting in the formation of creasing or surface cracks, which may lead to the leather contracting; however the urethane remains stable, which may lead to it delaminating.
A regular wipe down with a damp towel on a regular basis is all you need to condition and / or hydrate finished leather, and by using aqueous (water- based) products that do not contain oils and/or waxes, check the label if they do then don't use them. Leather should be hydrated on a regular basis and is somewhat climate dependent. Monthly hydration of leather upholstery in most southern states; Florida, Texas and Arizona, and etc especially during the summer months, would not be out of line
3. Protected - is essential as it will protect the surface finish, without hindering transpiration, while acting as a sacrificial layer; this way you are not actually cleaning the Leather's original surface, but cleaning from the surface of the protection. It also makes dirt easier to clean off
Leather Masterâ„¢ - Protection Cream (a Scotchgardâ„¢ type product specifically formulated for lather) the polymers penetrate the surface of finished leather and cross-link to form a durable protective film that is breathable, allowing transpiration and keeps the leather supple. Being aqueous (water- based) it restores moisture to finished leather and provides a protective sacrificial barrier against all kinds of soiling, water, oil, alcohol-based stains and perspiration marks, so you are cleaning the protective layer
3A. Ultra violet (UV) protection – 303® Aerospace Protectant will provide invaluable ultra violet (UV) protection against photo degradation (fading); especially in a roadster or convertible vehicle, steering wheel and dashboards
Is water-based and will provide invaluable ultra violet (UV) radiation protection against photo degradation (fading) protection; especially in a roadster or convertible vehicles. It doesn’t contain silicones, so it won't attract and capture dust. You should apply to a clean surface (it doesn’t contain any cleaning agents)
It will not prevent finished leather hydration (transpiration and evaporation of moisture) as it’s water-based, although it coats the leather with a micro fine coating; it will not seal it per se.
Note: this product does NOT air dry. Use a second dry cloth to finish the application process. Extra buffing with at dry cloth increases bonding, repellence and durability
Associated Articles
1. “Reference sources and bibliography used for leather articles� - http://www.autopia.org/forum/autopi...graphy-used-leather-articles.html#post1474865
2. A Brief History of Leather - http://www.autopia.org/forum/guide-detailing/137800-brief-history-leather.html#post1463189
3. Leather Tanning Process - http://www.autopia.org/forum/guide-detailing/137341-leather-tanning-process.html#post1455796
4. Leather Fat Liquoring and Conditioning - http://www.autopia.org/forum/guide-...r-fat-liquoring-conditioning.html#post1462908
5. Leather Restoration / Renovation - http://www.autopia.org/forum/autopi...ather-restoration-renovation.html#post1479003
6. “Types of Leather Used in Automobiles� - http://www.autopia.org/forum/autopi...pes-leather-used-automobiles.html#post1474058
7. “Leather Surface Identification� - http://www.autopia.org/forum/guide-...tery;-surface-identification.html#post1451654
8. Various Leather Surface Conditions and Correction - http://www.autopia.org/forum/guide-...us-leather-surface-conditions-correction.html
9. Leather care products - http://www.autopia.org/forum/guide-detailing/138006-leather-care-products.html#post1465895
10. Removing Stains from Leather - http://www.autopia.org/forum/guide-detailing/138225-removing-stains-leather.html#post1468879
11. Proper Finished Leather Cleaning and Care - http://www.autopia.org/forum/guide-detailing/136421-proper-finished-leather-cleaning-care.html
12. Leather Conditioning - http://www.autopia.org/forum/guide-detailing/137157-leather-conditioning.html#post1454835
13. Using Oil-based Leather Care Products - http://www.autopia.org/forum/guide-...-based-leather-care-products.html#post1450942
14. Aniline Leather; Cleaning and Care - http://www.autopia.org/forum/autopia-detailing-wiki/137167-aniline-leather;-cleaning-care.html#
15. Perforated (Nappa) Leather; Cleaning and Care - http://www.autopia.org/forum/guide-...nappa-leather;-cleaning-care.html#post1455017
16. Alcantara Cleaning and Care - http://www.autopia.org/forum/guide-detailing/137169-alcantara%AE-cleaning-care.html#post1455020
