American Muscle Clean-Up; Shelby Content
MarcHarris
I was fortunate enough to have the opportunity to work on this beautiful and very well kept Shelby GT500 Mustang. In addition to how much this particular muscle car is babied, I enjoyed this detail as the vehicle is made not far from me in the metro-Detroit area. As a metro-Detroiter, the Mustang is quite the iconic figure and I grew up surrounded by these beasts: with everything from the classic 67 designs, to sub 10 second Fox bodies, and of course the 'Stangs of the mid to late 90's.
I also felt lucky to have the honor of being the first person to wash the vehicle. The owner is very careful with his ride, and up to this point has always done quick detailer wipe-downs with microfiber cloths on the body and wheels, out of fear of ruining the finish by adding swirl marks. When I first met the owner and got to inspect the vehicle, I was shocked: this would be the first vehicle I've worked on that is swirl free. The owner was coming to me not only to free up time by having someone else take care of it, but to have me thoroughly clean small areas and give the exterior a nice layer of protection.
Upon arrival, here she is: White with metallic blue racing stripes, only slightly dusty
The owner expressed his concern with some grease marks and dirt in the engine bay, so I began with those issues after spraying the wheels with P21S Wheel Cleaner Gel. As nothing was horribly soiled, here's a look at the typical level of dirtiness
mechanic/dealer prints...
APC (10:1) + agitation with a Meguiar's Slide-Lock brush took care of things nicely
After a light rinse, I turned my attention back to the wheels. The wheel faces were all nice, but the lug-nuts, calipers, and inner barrels of the rims could use a little love.
before:
sprayed with wheel cleaner gel:
agitated with a (dedicated to wheels) Slide-Lock brush, barrel brush, lug brush:
after everything was said and done, here was the wheel turn-out:
in this one you can even see the time I spent getting the wheel weights cleaned paid off :)
The rims and engine bay were taken care of, then I moved on to give the GT500 a nice rinse and wash. Before I started however, I wanted to pre-treat some areas with APC and a little agitation.
Area around the third brake light housing
Swissvax brush dedicated to paint doing the agitating:
and flushed
some other areas that needed a little attention:
CAN'T have gunk in the Shelby badge!
with the plate off, the rear end could get a full and proper cleaning / claying / waxing
this is an area that decided to give me problems....
wouldn't come perfectly clean...little did it know I had Q-Tips!
After a gentle wash with a lambs wool mitt, I clayed the paint with mild clay. VERY little contamination, with the only areas to note being the lower panels behind the wheels
Dried with waffle weave towels in the garage for shade, then used compressed air to remove water from the grill and hard to dry areas
applied a layer of Wolfgang Deep Gloss Paint Sealant 3.0 (why such a long name Wolfgang?) to all painted surfaces to include the door jams, the edges around the doors, and the vinyl racing stripes
This sealant is extremely user friendly as it goes on smooth, thin, and is very easy to buff off once set. After removal, I turned my attention to the interior while the Deep Gloss 3.0 cured
Petals were cleaned with diluted Woolite; carpets got vacuumed; dash and instrument panel was wiped down with 1Z Cockpit Premium; leather was cleaned with diluted Woolite, then received a layer of Leather Master's Vital which was lightly buffed with a microfiber towel after 20 minutes
With the interior tidied-up, a second layer of Deep Gloss 3.0 was applied to the racing stripes / lower body panel emblems, and Dodo Juice Purple Haze carnauba wax was applied to the paint. While those protective elements set, the trim was treated with Meguiar's Trim Detailer spray, the glass got Invisible Glass, and the Exhaust tips were hit with Nevr-Dull. Last but not least, the bolts that hold the license plate on were sprayed with WD-40, as were the the holes they go in, then the plate was reinstalled
Thanks for looking, and I always appreciate any and all feedback!
MotorCity said:
Looks great MaRC
fixed ;) and thank you very much - means a lot coming from a guy of your talents
Sludge said:
Great detail and very informative write up. I learned a little about the finer points of detailing. Thanks for the terrific post. :xyxthumbs
thanx! surely was a well kept car, so it was all about the small details with this one!
CocheseUGA said:
Looks great. What do you use for your barrel brush?
Thank you, for inside the barrels, I sprayed from Meg's Wheel Brightener, then scrubbed with a brush similar to this one listed at detailersdomain because it's stiff and holds it's shape
Nice job Marc!
That orange peel on the blue paint beneath the third brake light is the worst I've seen yet.
dmw2692004 said:
great detail and write up!
thank you kindly
sharabi said:
Thank you Marc for the excellent job you have done, Am a happy camper....lol
thank YOU for the awesome opportunity on a well-kept vehicle. I look forward to maintaining its look
Heatgain said:
Nice job Marc!
thanks, and yes - the racing stripes are vinyl stickers. Because of the flake in the paint on them though, I went with two layers of sealant on them for clarity
jeteast99 said:
I thought it was vinyl
you are correct!
bufferbarry said:
great detail man! looks awesome
thanks barry!
David Fermani said:
Why is this not in the Pro Before & After section????
Awsome work on a hometown hero!!
Thanks David! fine fine fine, i'll start posting my work over there in the future. You'll like my next post: a 993 race car ;)
Mark - Jesse might get jealous that your cars have less swirls than his:angry
Anyhow, great job on that Shelby! This should have been in the Pro's section.
