Amazing Roll-off is really amazing.
gmblack3
I've been using Amazing Roll-off 1:1 (which still may be strong, I am going to try ARO 1:3 water) on the following:
Wheel wells and tires-Don't you just love that dealer or "scratch and shine" installed tire goop that slings all over the car and takes forever to scrub off of the tires? I've used some APC with a high ph level and 4x later the tires still are not clean. ARO cleans up these tires in 1x and sometimes it does take 2x.
(1x=wet tire, spray on ARO, let dwell for a few mins, scrub w/ brush and rinse)
On cars that are getting a polishing step, I wet down the front and lower panels of the car. I then spray ARO on, let dwell in the shade and work it with a blonde boars hair brush. Bugs, tar and all that other fun stuff that gets on the lower panels is cleaned right up.
Stained clearbra- The clearbra on my white truck was starting to look nasty. A few months ago when the pollen was in full swing here, I was doing more then a few rinse offs on my truck and putting it away wet in the garage. The truck was sitting outside for more then a week while I had many details to do in the garage. Mix the pollen with fallout from the trees around my driveway and it was really nasty.
Rinsed off the clearbra and sprayed it with ARO. Let dwell in the shade for a few mins, scrub w/ the blonde boars hair brush and rinse. My clearbra has not looked this good in a long time.
Gutters around the house-Mine look nasty as they have not been cleaned in a few years. I did a test spot above the garage door. Sprayed on the ARO, dwell, light scrub and rinsed it off. Now I can see the true colors on my gutter. A BIG CAUTION when doing this to the gutters, your wife will keep asking you when are you going to clean the rest of the gutters? Director:cursing::o As soon as the details slow down honey, thats when. :D
I too love ARO....though I have been using it straight only for tires....guess I need to try it on a few other things and start cutting it down! :D
FYI, I think my gutters have plants growing in them! :)~
I just picked up my first 32 oz. spray bottle of ARO. I did use it full strength on the tires and wheel wells of my "new" truck. Maybe I was expecting too much based on reading the many posts on various forums, but I came away somewhat underwhelmed. It worked fine, it just wasn't an "awe inspiring", "jaw dropping" experience as "promoted", and as the price of entry would have one to believe. I can get a gallon of AM's 777 or many other dilutable APCs for the same or lesser price than that 32 oz. bottle.
I'll continue to use it as it is a far sight better than the 303 industrial strength concentrate that also saw much forum fan fervor.
Interesting....
AMs 777 and even the "Red Hot" APC where my go to APCs for wells and tires before I got ARO.
I have been thinking about buying some ARO but the Meg's super degreaser 4:1 on tires has been working great for me. Even tires that are filthy, spray on, let it dwell then hit it with the brush and they all seem to rinse away perfectly clean.
How does it compare to Bleche Wite on tires?
I have not used BW in a long time.
were you cutting red hot? how do 777 and Red Hot compare? I can dilute red hot 1:4 water and it still cleans tires and wheel wells nicely.
A few times when I had tires with the dealer or hackshop installed goop, I used red hot straight and could not get the goop off using it 4x. It was better, but not clean enough.
Red hot is much stronger then 777.
I didn't reallize that ARO is an all-purpose-cleaner.
I always had it in my mind that it was just for convertible tops! (Don't know where that came from!:out:)
With these testimonies, it's on my list of "supplies to buy"!:)
