Am I on the right track?
impalaman1963
I know there's better products out there. But I like Meguiar's products.
Please add or subtract a Meguiar's product you like from each step that you use.
Wash
Clay
Polish #83
Glaze/Seal #20
Wax #26 / NXT II
impalaman1963- I never liked #83 all that much :nixweiss
I'd rather do the real correction with M105 and then finish with M205 or even #80.
If you do use #83, I'd follow up with something milder. I'm not even 100% satisfied with how M205 finishes out.
Just keep in mind NXT2 has enough cleaning to remove the stuff under it. So stick with #26, IME it looks fantastic on red.
I agree that #26 is a good (and available, and inexpensive) product for red, but I don't find NXT v2.0 to have any real cleaning ability. I've used it over leaves-stuff-behind products like Autoglym SRP and 1Z PP, and it never cleaned those off :nixweiss Note it's made to work OK over Meg's "pure polishes" and those aren't all that durable.
Should I try this combination?
Wash
Clay
Scratch X orSwirlX
Polish
Meguiars #105 Ultra-Cut Compound
Meguiar's Solo WDFP-7 Foam Polishing Pad W8006 or W8207
Meguiar’s M02 Fine Cut Cleaner
Meguiars Mirror Glaze #205
Sealant
#7 or #21
Glaze
Meguiar's Mirror Glaze #16
Wax
#26 or NXT II
Wash
Clay
Scratch X orSwirlX
Polish
Sealant
#7 or #21
Glaze
Wax
#26 or NXT II
You might need a 7006 pad with the M105.
You will *NOT* need to use M02 between the M105 and the M205.
The #7 is the glaze and I doubt you'll need that.
The #16 is a wax that you might want to use instead of the #26 (or not).
Personally, I'd just choose one LSP (#21, or NXT, or #16, or #26) and not make the whole thing so complicated.
