Am i just lucky, or does ONR EAT brake dust!?
gofastman
After washing a few cars with ONR (highly recomend you try it if you havent, btw)
I have found that it removes brake dust from wheels better than most wheel cleaners! Any one else experiance the same thing?
The wheels I did were sealed with NXT however, which I find does an excelant job of preventing contaminants from binding to the surface. My fealing is that it will also work great on unsealed wheels, too.
NXT+ONR= teh shinney wheels!
ONR does a very good job of cleaning away brake dust. I think I might have to try spraying it on and then agitation to see what happens.
I just did an ONR wash and it seemed to cleanup the brake dust quite well, I also added a cap of Bug Squash to the solution though... :think:
Are you guys using a spray bottle or a wash bucket for the wheels..either way whats the dilution ratio used in the spraybottle?
I'm going to have to try this. I hate how wheel cleaners will eat thru any sealants you put on it. I find that I can just wash soap and my Meg's brush. If ONR works as well as a spray and rinse formula, that is going to be awesome.
Before:
After using ONR and a few brushes and two towels:
I have been using it at 1.5 oz per 32oz spray bottle. I always have this around as a QD . spray it on and use your fav wheel brush. it does a real nice job. I am sure you can get away with using less ONR. I use it on my wheels at the same rate as regular washing but they are sealed . when doing my own I use an old chenille mitt or mf. looks like you now have a new idea to try out :spot I think Scott's pics speak volumes on how well it works :hifive:
Yup it does clean up brake dust. If some dust that is baked on, then that another case.
I use ONR to clean door jam as well(hate the accordian part).
After ONR..wheels are maintained with duragloss AW.As you can see wheel wax is far to tedious for these wheels..
Heres a shot of what the water looked like after i cleaned the wheels with ONR.
