Hey “JW�
I too had brake dust issues with my P-car. Since they’re some of the best braking cars on the road, they leave hefty brake dust residue all over the rims. When I must use a wheel cleaner, it's P21s and a 'baby-bottle-brush' to get the inside of the rim through the spokes. But that's rare as I’ve test a lot of different steps for a long-term-results, along with an easy-to-clean solution and here’s what I’ve found to be the best solution after 9 years of Porsches.
I’m a little anal and like when the back of the rim is as clean as the face, it really gives the rims depth when mounted on the cars, so I take the rims off the car.
Start with a light grade compound by hand to restore the rough & ‘bruised’ areas. Then, using a variable speed drill and a Mothers Power Ball over the whole rim with the same compound but generously misted with denatured water as I went, (NEVER run it at full speed!!!!)
With some quick passes you'll be amazed (I was) at the immediate results. With a different Power Ball, I switched to the Sonus Step 2, another ball to the Sonus Step 3.
Waxed the rims with P21S, let the rims sit for 4 days, waxed again, waited 5 days, and applied 2 applications of Rejex one day apart, never using the car between waxes and or Rejex. They gleam better than new!
The maintenance on them is a blast of the hose and wipe-down of the left over wash in the bucket after washing the car and I'm done! They shine, they're protected, and the finish is so slick brake dust barely accumulates.
If you’re as anal as I am and have an air compressor, you can (just about) blow the dust off the rims after a hard days driving with this technique. It won't be as good as a thorough cleaning, but it sure seems to help with the maintenance. (Wise advice from this forum has reminded me of the dangers of inhaling brake dust – so protect yourself if you use an air compressor).
The first time is a lot of work, but the time I save in cleaning them now is worth all the prep time I put in. I apply a new coat of Rejex every month (very easy to put on and take off), and I love the results, and (almost) never worry about the long term effects of constantly using caustic wheel cleaners.
“Accumulator's� advice is right on (usually is in my opinion) regarding getting all wheel cleaning solution off the back/inside of the rims before it dries. He uses different products too, but seems to have similarly easy wheel washing without constant caustic wheel cleaners.
Hope this helps.
