Clownn- Welcome to Autopia!
That looks more like abrasion-type damage than solvent-action from the IPA. Like...at least 6-8 circular/elliptical motions, each one of which was scratching the finish due to something pretty big gouging into the clear (gee, how could it go on for so long before somebody noticed what was happening?!?). Done with pretty much pressure too. Almost like the pad was still in its foil wrapper and the foil did the scratching, or a tag/seam on the cloth used to "polish" it (scare-quotes intentional).
Try polishing it with something like Meguiar's Ultimate Polish or even Ultimate Compound. Keep said products off surrounding areas and us as per instructions (with soft MicroFiber cloths that pass the CD-test). See if the results are OK and if not replace the piece. I'd be planning on replacing it.
Sad thing is that all that probably wasn't necessary. The piece may very well have been clean enough for the adhesive to stick without doing any prep at all. Getting that adhesive back *off* later might be anothe story! I'd use 3M Adhesive Removcer, which I might've used for the cleaning too, on a soft MF cloth or a foam swab, instead of the alcohol pad.
Stokdgs said:
Sorry you didnt notice this happening fast enough before it got ruined..
That's what I was wondering about...touch media against finish, gently move media a fraction-of-inch, inspect before going farther..how did it go on for so long?
