charlesaferg
Since there is no "aircraft" section, I'd assume I would find the best advice here.
First off, I landed a job detailing an aircraft after detailing a client's black Porsche 911 Carrera 4S, which looks gorgeous BTW - (pics will be linked at the bottom.)
Anyways, I have done some good research as to the process and other things. What I'm concerned about most is the products that I will need. I know that marine products are for gelcoat and fiberglass, and I'm not quite sure if this will suffice for an aircraft.
I figure that I should buy some heavy cut from megs, and use a heavy wool pad, then follow with a lighter compound and a foam or lighter wool pad.
Also, what is the correct product to use to degrease the underbelly?
Again, I have searched and have read through the threads already present on the board, so any information on these specific topics would be extremely helpful.
Heres the Carrera-
B4
http://a785.ac-images.myspacecdn.com/images01/42/l_5b07d6b54356960c726b6485339f6150.jpg
After, I apologize for the bad pic, but theres nothing but some dust and a dog hair
http://a949.ac-images.myspacecdn.com/images01/57/l_70a1a4a6dadaebf95d712fe6486100e4.jpg
http://a737.ac-images.myspacecdn.com/images01/60/l_921ca6f37bc614f496791a828b3b7fe0.jpg
http://a760.ac-images.myspacecdn.com/images01/12/l_661aafa4edf61b0c34467de8be066f67.jpg
http://a471.ac-images.myspacecdn.com/images01/59/l_68da0284fa64747674097b56a8f2dec6.jpg
Heres the Carrera-
B4
