AIO combo
classofshine
I have an idea, I really like OPT poli seal as an AIO, cleans, seals and you get a little correction. For swirled out messes I use D151 as it has a lot more cut then poli seal. The downside to both of these is that the sealants dont last all that long, maybe 2 months for me. I was thinking if mixing in a little 845 or even some DG 105. I assume Im going to get less cut with both of them. Has anyone tried this? Am I better off just topping these instead of mixing. Trying to find a way to cut some time out.
I've never actually tried this, but was told once by Dr. G @ Optimum that an ounce of Opti-Seal could be added to 32oz of Poli-seal to increase the protection.
Mixing products typically do not work, they are formulated to work in one way. The combo's don't always work. If your looking for a good solution, I would use a good AIO like PB P-w-C and then LSP with your sealant.
