imported_Detailing Technology
I have Menzerna IP, SIP, Power Gloss, and M105. Just looking for something aggressive to use with the rotary and twisted wool.
What are you using?
What are you using?
jdoria said:A little lighter, I still have some of that 3M gravel in glue mix.
BigJimZ28 said:why not try the products you have?
then see idf you need something else
jdoria said:Pads maybe? I'm using Lake Country CCS yellow, white, black on most finishes
jdoria said:I've tried them all a ton of times. I did 42 customer cars in 08 and I've done 12 cars so far in 2009.
Maybe the new M105 formula with 205? I just think I spend way too much time on my first pass on a bad car.
David703 said:Hi Temp extreme cut or Power Gloss.. never ever needed more than those.. and all with foam pads and rotory
jdoria said:Agreed on the "need". Power Gloss was sub-par compared to M105 to me.
What about your time? I seem to spend a lot on foam/105 or foam/SIP in my mind.
