Freddotron said:
I've got some BFWD on my ride right now. It looks unreal but I find it to be bad for water spots. What would be a good wax to put over this to:
a) extend the life of the Sealant
b) Keep the water spots away
c) look damn good
I was thinking of trying AGHD or CG 5050
Thanks for your help
Fred
If you want to extend the life of the sealant, I would probably just add another coat of BFWD. Keep in mind, once you top a sealant with a wax, you can no longer apply another coat of sealant (without removing the wax and therefore the sealant under it) because a sealant cannot cure to a wax.
Not sure a wax would help much in that regard. The best way to keep waterspots away is if it rains, wash the car and when you wash it thoroughly dry it afterwards.
c) look damn good
A wax can only help to a small degree. As mentioned in other threads, the amazing depth and wetness you see on some of the freshly detailed cars on this site is 95% due to that detailer's skill in paint correction, not the sealant or wax they used.
Take two identical cars that are equally neglected. You put the best sealant wax combo one. The other, Scottwax, David Fermani, or one of the other top detailers correct by polishing in multiple steps and apply nothing to to the surface. The car with no sealant or wax on it would blow the other car away looks wise. Probably not want you wanted to read but is ultimately the truth.
