TigerMike said:AquaWax is just what you're looking for. It's very similar to Z8 and will provide greater slickness and protection to keep crud from sticking as easily. I have found that AW has very good crud resistance. And, the best part...at $7-8 a bottle, you can use it much more frequently than the expensive Z8. I use AW after every wash or every other wash. Save the Z8 for those special occassions when you really want to use it.
AW is OTC in many areas...look for a CarQuest and they should have it.
TigerMike said:AW is not a QD really. It is a spray wax/booster in the same manner as Z8. Z8 and AW aren't meant for QD application really as they have no surface cleaners. AW on it's own will typically last a couple months, maybe longer depending... AW definitely adds protection...and lots of gloss.![]()
NSXTASY said:As far as durability, personally it doesn't matter so long as it lasts a couple weeks. *Lasts* meaning slickness and gloss remain relatively unchanged. However, I have not found either one to last *months*. Maybe 4 weeks tops, after that its a difficult determination as to whether initial protection is there.
TigerMike said:I The AW quit beading and returned to the prior sheeting phase at around the 2.5 month mark, leading me to believe AW had pretty much held on with some protection for at least 2 months, and then began to fail. At 4 weeks, sure the beading isn't as uniform and very very tight like week 1, but it's FAR from the dead/sheeting action seen when it's completely gone.
TigerMike said:AW can certainly be classified as a spray sealant if it's going 2+ months on a car sitting outside all day every day. And, I have seen similar results from Z8. Z8 isn't lasting any longer for me, so why call it a spray sealant either? I would certainly challenge some other dedicated synthetic and natural waxes to last as long in the same environment as either Z8 or AW. Personally, if it lasted longer than 1 month, I'd be apt to call it a spray sealant. If it didn't last longer than a month, I'd call it a QD...
NSXTASY said:Obviously, AW could be categorized as such, but I havent found AW to add much for looks or as good protection by itself.
BlkTac05 said:But for me, Z6 is the QD to use after washing when using the Zaino system. Use Z8 sparingly to enhance the looks and durability of Zaino. Once a month should do the trick. For weekly washes, go the Z6 route.
