The orange is a light cutting pad. Technically if you used an aggressive polish/compound often enough I guess you could cut through the clear coat, especially with 4" orange pads. Realistically you'll use the orange pads to initially remove defects, scratches, swirls, etc. from your paint. After that you should develop your washing skills to the point you don't need to use the orange pad very often if at all.Egoolps said:...........I was reading about the orange pad, and it says it cuts into the clearcoat. Even though it's minimal, at one point will the entire clearcoat be gone from doing this?
Don't hesitate unless you're thinking of buying a Flex or G110 instead. A good DA polisher will make your life a lot easier and with just a dab of common sense they are very safe for your paint. Read the following DA guide to get a bit familiar:Egoolps said:I'm thinking of buying the Porter Cable 7424, but I'm starting to hesitate..............
JasonC8301 said:I believe you will not burn through the clearcoat with a Porter Cable 7424 unless you get a rock stuck in the pad or use an ajax paste as the polish..
