After a 12hr cure time of WG sealant ?
Mary B
I`ll be using WG Glaze & Sealant on my DD Thur.
I want to apply WG spray wax. After the 12hr suggested cure time the truck will be dusty,
So I`ll have to wipe her down with :
Eraser (what I usually use)
OPT. PP ( have, not used yet)
or maybe WG Rinseless in QD ratio ?
Any suggestions or advise would be helpful :thanks
Why use Eraser on freshly applied LSP? It`s probably too strong, as it cuts polishing oils decently well, which is what it was made for. It may cut through the LSP. ?
my go-to for a dusting in-between layers (of anything) is PB Spray & Wipe, as it leaves very little behind.
