aerospace 303 substitute?
skuzy
hi everyone...
Im looking for a alternative to aerospace 303 product... no real complaints about this other than it makes my car stink to high heaven like B.O !!!
the last thing im wanting is a nice clean shiny car only to stink like 50 sweaty arm pits
Any suggestions? Intentions are to keep this bottle and use it for the engine bay only.
Thanks in advance.
Einzett Cockpit Premium will work for you.  No more 50 SAPs
Edit:  I just noticed that was your first post.  Welcome to Autopia!
Mothers VLR - great stuff, gallon size avail
Megs Quick Interior Detailer- works great on everything including NAV and gauges
I love a303, but haven't found a good alternative.
Optimum tire gel is pretty good, but 303 is superior.
What are you using it for inside that is making it smell?
I mainly reserve this for rubber gaskets in for frame and such.
skuzy- Welcome to Autopia!
Like bunkeroo26, I can't help but wonder what you're using it for.  I do like it for some (very limited) applications, but most of the time mine just sits on the shelf.
well - i feel abit rude to do an intro like this but i was a member of this forum a long way back... the forum has changed and surprisingly my log in still works! lol !!
back when i was still in love with cars.. i had the impression from reading around on detailing processes & product recommendations that aerospace 303 was the beez neez for cleaning / restoring the interior.
I use it on the dash, doors, handles, etc when cleaning the inside before vaccuming
have to say i still love the deep colour it puts back, just not the smell..
I also have had good luck with <span style="color:rgb(40,40,40);font-family:'helvetica neue', helvetica, arial, sans-serif;">Einzett Cockpit Premium
Had a customer who wanted shiny interior.
I finished parts off with Opti bond.
I personally didn't like the shiny appearance, but he was happy.
I have never tried cockpit premium, but I use to love Meg nxt.
They say that cockpit shine is the nxt, but I am unconvinced.
It sounds as if I should try cockpit premium.
Does it restore Faded interior also?
skuzy- Sorry I didn't recognize your user-name, now that you mention it, well...yeah, it does ring a bell.
Some people are *really* sold on the 303's UV protection (not me though).  If that's not a big deal to you, I too love the 1Z Cockpit Premium, and I also use Meguiar's Interior QD.  Both smell nice IMO and do impart a little bit of sheen.  I wouldn't go so far as to say it "restores faded vinyl", but then I've never really tried to do that, at least not recently.
AutoGlym's interior vinyl/etc. dressing (forget the exact name of it) was something I did like when I wanted a "more is more"-type product as opposed to the less-is-more stuff like the two I mentioned.  It was a bit less slimy than most such products and IIRC it had a light and clean scent.  Autoglym stuff doesn't get much mention here, but IMO it's generally a very good line.
I love ONR cleaned interior as the smell is nice.
Then followed up by some good protectant of choice.
Just like Accumulator, I am not sold on the UV protection of 303.
Where it excels is hydrating and restoring soft rubber.
I want to believe that this is made for exterior application.
If you do want to use it on interior, perhaps there is a way to achieve this.
Would it cut the smell down if you work in the product, then remove it?
If I understand the product, you wouldn't need it to dwell on the surface,
the protective chemicals should be absorbed into the surface quickly.
I am unsure what to clean it with, because you would want something mild
to remove the scent but not the protection. ONR possibly?
I hate to talk about it like it is a do it all product, but it is. I love it.
As a parting thought : how much 303 are you using?
When I use it for trim, a little goes a super long way.
Perhaps just cutting down the product used will help.
ETA: another thing to try is diluting the 303. You should still get
the affect needed at lower dilution. Also, if you use tap water, this
sometimes causes solutions to lose their scent.
Let us know what works, if anything
thanks for all the replies folks.. took 2 days before the smell dissipated lol...
In terms of application..no special process really.. just spray enough rub it down and buff it off and try not to get any on the leather or windows
ill do some searching on other products mentioned above..
cheers!
I don't know if this helps any or not, but to be honest I usually just use ONR at QD dilution and it does fine for me. I'm not a huge fan of my interior being shiny and I don't have to worry about getting stuff on windows since I do the windows with ONR as well.
If I'm doing an interior for someone else I use Meg's Quick Interior Detailer. It does what it's supposed to. When I do use 303 I use it on exterior trim.
Carpro PERL would be my recommendation, actually switched from 3 different dressings to this one for my clients. Great dilution ratios & covers all the bases
I have used aerospace 303 for 15 years.  It kept the exterior vinyl trim looking black like new.  It did wonders on a Volvo with black vinyl trim I kept for 11 years.  Kept the trim black and matte.  I used to compare the vinyl trim with the same model volvo of similar (or less) age and the difference was remarkable.  Even the dealer commented on it when I traded in the car.
I used 303 on interior plastic surfaces and worked fine there as well, plus on tires.  Never noticed any smell.  Only drawback is it is expensive and hard to find (I get it at a marine store).
Cannot recommend using 303 on leather regardless of "coatings" they supposedly use on new leather.  I use leatherique but it's a drawn-out multi-stage process I can only do 1-2 times a year because it takes so long.
I used armour all before 303 and it cracked my tires.  I still consider Armour All to be poison.  Maybe that view is outdated and they have improved the formula, but I cannot forget my cracked tires.
Yes, Aerospace 303 will "stink"  like B.O. if it has been frozen for some length of time. Once the emulsifiers that are used to keep the chemicals suspended (emulsified) with the water freeze, it changes their chemical (molecular) structure, and hence, this weird smell. (Resident chemist Jon Miller a.k.a. TOGWT may chime in) Chances are this may have happened to you if you stored the bottle in your unheated garage during the winter (depending where you live) OR the bottle you purchased was allowed to freeze OR shipped to you during extremely cold weather.
this is interesting info. I have had the same gallon of 303 for several years and never noticed a bad smell, was confused by this thread. I'm in houston so freezing in the garage wouldn't happen
guess i'm old school, still love my 303 :)
