Adding QD to car wash mix
C-MDX
I'm not sure if this has been discuss before but can you add QD to the car wash mix so you don't have to go through the car again after drying?? I do have WAUD.
I doubt it. Even if you washed your car with a bucket of QD, the final rinse will more than likely take the QD off with it. Spraying QD/WAUD on a wet car to assist drying and improve slickness may be a better idea. :up
I've been adding a half capful AIO to my wash bucket for my Klasse'd cars. While AIO kills the suds, it gives an added dimension to the wash as a chemical cleaner. I've been seeing little to no improvement to QDing (EO or Sonus) after washing with AIO added. It also makes the surface slick. I tried adding a layer of SG after a wash like this and it seems to be a good prelude to it.
The very minimal amount of AIO will at most clean the paint contaminants off. You would need a lot more undiluted AIO to take off SG. It could possibly "exfoliate" but not completely remove the SG. The slickness is either from AIo itself or from the "exfoliated" SG surface, I don't know. I really didn't get any improvements with an after-wash qd.
Why dont you just use a good polymer based wash and wax and not the usual suspecs. you get at the store ( they add parifin wax ). This would be more cost effective and would give you a superior final product
tdekany said:
A painter friend told me once to add Mag's #7 to the car wash to get a nice wet look in a hurry.
It works for me every time.
Wow, now that's different! How much do you add? Any residue / rinsing problems?
To make things quick I pour my shampoo, polish, wax, and trim protectants all into a bucket of water. Then I pour it over my car and I've done everything at once! Never heard about the #7 trick, very interesting.
I use 1Z Perls which already has polymer protectants. After each wash it looks as if it has just been QD'd.
every 10,000 miles I detail the engine on the rx8 add a gallon of 5w30 and a cup of brake fluid to the wash topped with a screenwash and steering fluid rinse .
saves me £Â£Ã‚£Ã‚£Ã‚£Ã‚£Ã‚£ on main dealer servicing: down :down
he he he
seriously though polymer polishes work by leaving a layer of polymer in the case of AIO on the panel
I doubt if it will bond to a wet panel
Got any pics of the drive..............................
thats where all the polish is
A high quality polymer wash and wax will cationically bond to the painted surface leaving gloss and lasting protection
