add more to my process?
2000firebird
well, my process is pretty simple, i'm wondering if you guys could recommend some additions for me. i like the results i still have minor marring. my goal is that mirror like finish.
my current process:
nxt wash/ or gold class wash
ssr 2.5 blue pad @ 5k w/PC(should i spend the money to get a green pad?)
ssr 1 blue pad @ 5k w/PC
nxt tech wax by hand
Disclaimer: I don't use the SSR line and I haven't used the Sonus pads.
Yeah, I'd use a more aggressive pad with the SSR 2.5. Might also want to crank it up to 6.
It depends on many things such as environmental factors. Under normal circumstances maybe once or twice a year should suffice
Make your passes with the PC nice and slow. When I first used one I was expecting too much too fast. You might have to make two or three very slow passes.
Are we talking minor marring or swirls? If marring is the issue, SSR2.5 might be a little too much. SSR1 with a green pad will do the trick. Additionally, the Sonus SFX 2 pad is quite nice. Use the blue pad for chemical paint cleansers and LSPs.
the car has been pro detailed once before, but its still got minor swirls, looks like il be adding a green pad, clay and some patience.
do you think throwing AIO in there would help ?
